A few friends and I are going to the drags for a few runs and settle who's car is quicker down the 1/4 mile
I thought I might as well post it up here and see if anyone else wanted to go
Ill work out the final details when I find out what numbers we have
People that are in
SirSkyline
Col
IanB
Bunta
FineLine
https://www.sau.com.au/forums/topic/156883-going-to-the-drags/
  • Replies 153
thought you would col good work
Hey can you delete the thread I made in the QLD section. I put there by mistake
Beat you too it... :)
I cant wait, i was only saying last night to mates at drinks that we need to get out to willowbank asap...
Their responce was well it would have to be a saturday (as they all would have a hard time getting to a wednesday night)...
So i just suggested this date to them like and hour ago and bam here it is...
SAU TNT... Yeah...
if I have my stuff sorted by then im keen
Of course you will Ian...
Even if you dont it would not hurt to get a base line run before you go on the modification trail...
In at this stage!
YEAH... Let Anna have a run too, i let Renee have a run in my car back in July last year... She was a second slower than me, but i smoked the clutch before letting her have a go... >_<
So she did very well to be honest...
she can run the R33 ;)
I will be too busy trying to get running the R32 down to miss out on track time! Once I nail the 12.5 she may be able to have a turn but :laugh:
If I can find some rims and gumballs for the rear by then I will definitely be in. >_<
Dont worry about it... Just run your street rubber...
It then gives you a good base line to run off when your talking about how fast your car is...
Im just gonna run my daily rubber...
Well I aint. the rubber you guys are calling standard and what I am wearing are 2 different things. >_<
What does that mean???
Forgive me, but i dont understand... Are you saying your rear tyres are worn out already...?
What you been up too in the last 48hours hey? ;)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
