  • Replies 56
hey yeh ive got pics of mine stock s1 bar u can do it but uve gota cut out a big chunk of the front reo angel the cooler back and a fair bit of cutting off the rear off the bar but it can be done with out seaing it from the out side pm ue email and ill send sum to u
Can you leave your bar looking completely stock from the outside if you cut a bit of the reinforcement bar?
Is it ok with the RTA etc to cut some of this bar?
Anybody got pics of a Justjap install that looks sleeperish?
Thanks
Here you go. Mine is a standard series 1 bar...NOT type M
Had to grind off quite a bit of the back of the front bar and shave the back of the indicators. Piss easy with a cheap angle grinder. (reo bar will require a decent cutting disc though)
Here is another one mate, exactly same as for a four door. The Reo needs a little trim and there is plenty of excess bumper you can remove with no adverse look. Indicator lights can sometimes need to be cut but there are certain types that will fit without modification.
No you can't. you definitely have to chop the frotn bar.
I absolkutely would not chop the front bar reinforcement at all.
Yes, it VERY much is a roadworthy item. You will die easier in a collision and it will void your insurance.
The front bar reo (useless as people think it is) ties the two chassis rails together. In a collission, the reo causes the chassis rails to take the force. AS you know, the chassis rails run along the car, so it's in the direction of the collision for a head on.
If you don' thave the reo, in a head on collission in the middle between the chassis rails, there is essentially notmuch stopping the item e.g. a tree from going straight through, and punching your engine backwards through the firewall into the cabin. How much do you like your legs?
Also, it ties the chassis rails together sideways. If you get a hit from the front side, instead of one chassis rail taking all the hit and getting bent heaps, the load is spread over to the other one too.
I have a friend who's insurnace was voided. He ran head on, into a traffic light pole at about 70ks. The pole punched the motor backwards. You guessed it. No reo at all. He removed it to fit a veilside front bar. Insurance voided. He lost his car, and he had to pay for the traffic light! Imagine if it was a speed camera. Do you know ho wmuhc those are worth?
Out of everything you can modify on a car, please don't play with the impact protection. Its like why don't you just chuck out the side intrusion bars for weight reduction.
You CAN install a fmic without chopping the reo. I have done it a few times on a skyline. I won't install one if it requires chopping.
Edited by MANWHORE
Thanks Chris..want to make sure it's still legal!
Scott, yours looks great. I wonder if I could do something like that without trimming the front bar reinforcement...my 4 door is same colour etc.
I just had a look at my car and I reckon unless you used about a 50mm core you would not be able to get it in there without trimming the reo bar...
Edited by benl1981
On the sII r33s you can fit it inside the reo. Is yours a sII?
Also, If you cut the front bar neatly/get a new frotn bar, it will allow you to fit omsehting big in front of the reo.
On the sII front bars, there's this big section at the mouth of the bar, where it just goes back and does nothing. If this section is trimmed neatly, so that the mouth doesn't go back as far, you can't tell it's trimmed
Read his first post. It's an S1 and he wants ti fit a FMIC behind his S1 bar and not his S2 bar or a new front bar.
Also...please dont compare your less than smart friend's idea of removing his reo bar to our suggestions of trimming it. Two different scenrio's. Engineers clear trimming all the time....as long as the cut is clean an the surface us treated with corrosion protectant after. It usually only requires 10mm max of trimming. This is mainly due to the design of the pipes that came with the cooler or the brackets that came with it. I dont think anyone on here was thinking of taking out their reo bar completely.
Looks cool. Perhaps drill some holes into your number plate more towards the middle so you can mount the plate across the bar rather than dangling.......
Ben, yes, any structural modification to the car must be engineered. Just because you make it clean, doesn't make it legal or roadworthy.
Just because engineers clear it, doens't mean that it's good. Anything that you take from the reo is making you that amount less safe and allowing more damage to occur in an accident. Also, that's not what most people do from the pics i've seen on sau. Most people seem to chop the whole front of the reo off.
I'm just letting Ben know of the possibilities that can occur when the reo is modified or removed.
Also letting him know that with ingenuity, it is possible to install one without modifying the reo. On a sI, My friend has a smaller jap core with piping on the same side which is smaller than the typical just jap kit and it fits without the reo being modified.
Also, if he needs to get a new front bar, then so be it? Better that than chopping the reo
Edited by MANWHORE
I had my hybrid cooler fitted at Platinum in Rydalmere. They had to take a little but off the BACK of the front bar, but I don't believe they cut the reinforcement. They had to trim my fan blades to clear piping. But thats all. It was a hybrid kit and a type M front bar (R33). You cant tell from the outside that the front bar had been cut at all..it looks very discreet.
They charged @250 installation
The guy I spoke to is Danny
i have a blitz front mount,uses all standard piping but still had to have 25mm trimmed out of the BACK of the reo,i'd like to see someone fit one without trimming the reo!!!!!!!!!!!!and for the mspec bar all they need is the bottom air duct trimmed back
Edited by mjones
The rio thats removed when you fit a front mount to a S1 aint going to stop any pole at any speed, and don't you take your car to get engineered so that they can assess if its safe not how it "LOOKS" and usually a neat job is done right hence its being passed.
And your mates insurance could have been knocked back for any reason tires bald, not informing company of mods and at 70ks if they could tell that the rio was missing amongst all the carnage then I salute them.
Cheers Matt.
  • 3 weeks later...
Are you saying that you have had a car engineered with the reo "cut or trimmed"?
I spoke to an engineer who said he would not pass my car due to the reo being "trimmed"
Can you pm me his contact details so i can speak with him about the matter further?
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
