Hi guys,
So many questions, hoping to get some opinions on the best diff/s I can get for my circuit tuned R32 GT-R.
I had a standard torsen in the MX-5, loved it, getting the tail out was nice and predictable but it always snapped back in quite violently. My mates Cusco 1.5way in his MX-5 was a lot better all around.
I've heard I need to replace 2 of them in the GT-R. I'm just unsure of what to get. Any opinions and experiences would be greatly appreciated!
https://www.sau.com.au/forums/topic/157199-best-diff-for-circuit-tuned-gt-r/
my opinion. 1.5 way rear. 1 way front. as for brands, I think the cusco diffs are quite good and at around $1200 or so not bad price wise either. from memory the only difference between the MZ and RZ is one of them has springs to put preload against the clutches and the other type uses conical washer type things at each end of the stack to acheive the same end. difference in price is about $80 between them with the spring type more expensive.
well the stock front diff is nothing fancy. but the rear diff is a pretty good thing for track. it's already a 2 way mech. the only thing that varies is the condition it's in which will obviously affect it's performance.
cheap way out would be buy a front 1 way, and get the rear rebuilt, and re-shimmed with a little more preload on it, but I know mine is already quite tight and will spin up the inside wheel with tight, slow turns.
I was looking for a similar sort of thing.
With regard to the one way fronts there are actually four options (I think).
Type RS (low initial torque)
Type MZ (Initial torque created by the cone plates)
Now both of these come with either 35 or 45 degree cams.
So what does it all mean. Dunno. But I would think an RS would be preferable?
Well that is fair enough. A two way will give you some push understeer on turn in. In a GT-R this is probably last to very last on the things you want to have. Hence the 1.5 way at the rear.
On the front I was of a mind that the more gentle in transition the better off you will be. Maybe I am wrong in that - they don't seem to torque steer, so maybe a more sudden cut in will be ok.
My original diff wore out, it was turning the inside tyre on the slow corners at corner exit.
I ended up putting in an ATS 2-way, then it became a drift machine.
Got the front transfer case modified and now it works great.
The only downside is when driving around at slow speed the rear end vibrates from the inside tyre turning at the same rate as the other, similar to a locker. Not that noticeable on street tyres...
Front diff is stock...
Would anyone consider a Quaife front diff (torsen type) and a 1.5 way Cusco / ATS clutch-pack type in the rear? That way you can get the progressiveness of a torsen LSD in the steering end, with a positive clutch-style engagement in the rear?
Or would that just unbalance the car?
That is assuming that Quaife makes a front diff for the GT-R.....
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
