Hi guys,
So many questions, hoping to get some opinions on the best diff/s I can get for my circuit tuned R32 GT-R.
I had a standard torsen in the MX-5, loved it, getting the tail out was nice and predictable but it always snapped back in quite violently. My mates Cusco 1.5way in his MX-5 was a lot better all around.
I've heard I need to replace 2 of them in the GT-R. I'm just unsure of what to get. Any opinions and experiences would be greatly appreciated!
https://www.sau.com.au/forums/topic/157199-best-diff-for-circuit-tuned-gt-r/
my opinion. 1.5 way rear. 1 way front. as for brands, I think the cusco diffs are quite good and at around $1200 or so not bad price wise either. from memory the only difference between the MZ and RZ is one of them has springs to put preload against the clutches and the other type uses conical washer type things at each end of the stack to acheive the same end. difference in price is about $80 between them with the spring type more expensive.
well the stock front diff is nothing fancy. but the rear diff is a pretty good thing for track. it's already a 2 way mech. the only thing that varies is the condition it's in which will obviously affect it's performance.
cheap way out would be buy a front 1 way, and get the rear rebuilt, and re-shimmed with a little more preload on it, but I know mine is already quite tight and will spin up the inside wheel with tight, slow turns.
I was looking for a similar sort of thing.
With regard to the one way fronts there are actually four options (I think).
Type RS (low initial torque)
Type MZ (Initial torque created by the cone plates)
Now both of these come with either 35 or 45 degree cams.
So what does it all mean. Dunno. But I would think an RS would be preferable?
Well that is fair enough. A two way will give you some push understeer on turn in. In a GT-R this is probably last to very last on the things you want to have. Hence the 1.5 way at the rear.
On the front I was of a mind that the more gentle in transition the better off you will be. Maybe I am wrong in that - they don't seem to torque steer, so maybe a more sudden cut in will be ok.
My original diff wore out, it was turning the inside tyre on the slow corners at corner exit.
I ended up putting in an ATS 2-way, then it became a drift machine.
Got the front transfer case modified and now it works great.
The only downside is when driving around at slow speed the rear end vibrates from the inside tyre turning at the same rate as the other, similar to a locker. Not that noticeable on street tyres...
Front diff is stock...
Would anyone consider a Quaife front diff (torsen type) and a 1.5 way Cusco / ATS clutch-pack type in the rear? That way you can get the progressiveness of a torsen LSD in the steering end, with a positive clutch-style engagement in the rear?
Or would that just unbalance the car?
That is assuming that Quaife makes a front diff for the GT-R.....
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
