hi i got a r32 gtst with a rb26 in it and im sik of my shit rb20 box
if i wanna put a rb25 box do ihave to change the tail shaft if so who someone good to do the tail shaft in syd do i use a 33 tail shaft
what else is involved in this conversion is the fly wheels all the same in 20,25,26s
https://www.sau.com.au/forums/topic/157302-rb25-box-in-r32/
Whats so shit about the 20 box? They are under rated IMHO.
For the 25 box install, you need a custom tailshaft thats about the length of the 20 shaft but with a 25 yoke to suit the gearbox output shaft. Measure it on the car to be sure you have the lengths right.
You need to muck around with speedo drives and there's a bit of playing around with the crossmember.
There are a fair few threads floating around covering this topic with a fair bit of detail on speedo drive conversions and tailshafts.
https://www.sau.com.au/forums/topic/157302-rb25-box-in-r32/#findComment-2922057
OK cross member depend on what you have in the car at the moment if you go from auto to manuel in an r32 with the rb20 gearbox you need an s13 xmember but from an auto to manuel r33 box you use the auto x member the mounting points are different from auto to manuel .In your case being already an manuel when I did my reseach for my conversion I was told the original manuel one fits well maybe just a little modification. It all depends what your car was b4 the rb26 went in
https://www.sau.com.au/forums/topic/157302-rb25-box-in-r32/#findComment-2932280
If your R32 started life as an auto, apparently theres no need for xmember butchery.
If your R32 started life as a manual then there's no way around it. You have to butcher the std xmember.
Mine chewed third gear. But the box had done 200,000km's odd and had 4years of my slapping of gears. What was scary is I was hardly giving it much when it let go so it can happen any time really.. On a long trip. :S
https://www.sau.com.au/forums/topic/157302-rb25-box-in-r32/#findComment-2932767
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
