Hi people just want to know how much power can be made out of these turbos R34N1 turbos C106/GT25 A/R 0.60/0.64 and when will i see full boost on an rb26?? are they ball bearing??
also what is the max power you can get out of the standard r32 gtr air flow meters??
and is there any way to get 350RWkw (not 4WKW) out of the standard r32 gtr intercooler. don't forget this car will only be on high boost for very short period's of time??
Cheers
anthony
Edited by black sky
https://www.sau.com.au/forums/topic/157371-any-info-on-these-turbos/
Ok, because you dont wanna search
I've done it, please in future use it. There is a wealth of information. Users cant be expected to post the same stuff week after week :)
http://www.skylinesaustralia.com/forums/in...&hl=*R34N1*
Obviously there are more threads, i just dont have the time to go finding them all.
Please spend 10 mins looking around
Cheers
post-2054-1172057834.jpg post-2054-1172057865.jpgpost-2054-1172057893.jpgpost-2054-1172057945.jpgpost-2054-1172057972.jpg
sorry about that i thought i could get some specific info on these turbo's
does anyone know when i would see full boost on these turbo's on a car that doesn't have cam's or cam gear's. I've heared they are fairly laggy and full boost isn't seen before 5000rpm
cheers
anthony
Cheers
cheers
anthony
cheers
anthony
i'd say the 5000 is about right. i remember them on my mates 34gtr and they were very laggy. his car was close to standard tho with dumps and exhaust.
cheers
anthony
What do you mean by full boost?
:P cheers :P
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
