Has anyone come across the following?
Recently installed a gearbox from a wrecker and a brand new clutch - when the car heats up this box was getting hard to go from neutral to 1st gear (it almost feels locked out until forced). Not all the time though, but the majority of the time. Second gear would give similar problems. 3rd 4th 5th all fine.
I took this back to the wrecker and got a replacement, however this replacement is doing the same, and now crunches a bit in reverse.
Has anyone experienced similar? Any suggestions?
Friends have suggested the clutch not disengaging properly, but what steps can be done to verify? Is it just another shagged gearbox?
Edited by raasclaat
https://www.sau.com.au/forums/topic/157372-crunchy-gearbox-when-hot/
mine does the same crap im putting up with it till it blows and then im getting a whole new gearbox
put thicker oil in it. the oil in it now must be gettin to thin when it heats up
Im not opposed to fixing the problem, as i wish to the sell the car and want it to be fine.
It has Redline in at the moment (fresh) ..so Oil isnt the issue.
I am interested in this Slave/Master cyl issue, but would like more info on it..
What am i looking for when inspecting the units?
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
