Autosports "ultimate Control" Skidpan No#1, March 24th Oran Park
  • Replies 136
Sorry Corinne,
Not doing this day - car is going to cop an abusing over long weekend so I want to save it for that.
I'll most likely do the next day of this.
I dont think helmets are required for shid pan days, Its been so long since I did one though!
Jeff what rubber you planning to use?? Your goin to be all over the course with that stuff you got on there now
Edited by Risking
yeah i know :huh: thats half the plan, i havent got enough time to get organised. if i manage to change brake pads before the end of the week i'll be happy enough. unless your offering?
i am going to have to give up my spot because my car is not ready and i had to spend a few hundred $$ on it last weekend so it will put me out if i go..
Thats fair enough..
We make Corrine Run... :(
Oh ha ha.. so not! Car needs some work..
So Corinne - what happens if we dont make the 40, do you know? The day will still run with a smaller field?
Im pretty sure we will just be running a smaller groups then.. It will still go ahead either way..
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
