if you are building a set-up like that i would suggest you find one. there are enough kicking around that people have been saving for builds etc. if you have the dough, then buy one.
  • Replies 55
well I'm assuming you are in the states, but even 20K USD is a long way off building the type of car you are talking about. it's not just a matter of buying a 2.8kit, a T04Z and a V-cam and then ships ahoy matey. you will need all new pulleys, harmonic balancer, prepped N1 block, complete re-done head (try buying 24 titanium valves, double valve sprins, retainers, cams, guides and then having it put together) if you want big HP and big RPM, and you want it to last more than a few passes you will need the BEST of everything. add to that a quad plate clutch, a dog gear set (or would sir prefer hollinger sequential at $22K AUD?), then add your new intercooler (cost $2.5K AUD alone), new radiator, twin oil coolers, diff cooler, trans cooler, bearings, gaskets, engine assembley, ignition system, ecu (i'd suggest motec for this set-up), injectors, fuel system (twin pumps, surge tank, all new lines both return and feed, twin feed rail, fuel reg etc). let's do the oil control. you'll need custom dry sump set-up with at least a 4 stage pump, boot mounted tank (with warmer) and all plumbed up properly. then full custom exhaust and intake piping, since we have come this far let's make it titanium as well. now you will need some nice wheels to go with your $80K set-up and some tyres to go on them. and don't forget the rest of your car is still standard and looking like crap. so lets throw in $10K on body work (conservative), and around $5K on suspension. then leave $6K for brakes so you can actually stop. now you are going to run your 900hp GTR (or whatever car it is today) at 12,000rpm on the street, so you had better be prepared for regular check-ups and inspections. may as well lease a workshop for a year, and hire your own private mechanic as there will be a years work to do building your car for one man no problem.
$20K USD will buy you fck all on that list.
Nothing further at this time your honour :P
ok i've been to nengun, and the total of parts (minus shipping) for the follwing came to $35 076. Now this doesnt included, gearbox, braided lines, N1 block, water pump, exhaust, engine assembly, block prepping, head building/porting and other things.
the list:-
APEXi - Power FC & Hand Controller
Nissan - Skyline - BNR32/BCNR33414-AN029AU $ 821.301
ARC - Super Micro Radiator
Nissan - Skyline BNR32 - 55mm CoreSMC55BNR3203AU $ 1,655.101
Blitz - SBC - i-D III
SBCi-D III Silver15085AU $ 480.281
HKS - Adjustable Fuel Pressure Regulator
Universal Fuel Regulator (Adapter Not included)1407-RA015AU $ 147.781
Fuel Regulator Adapter RB.SR,13B-REW engines14007-AK001AU $ 74.631
HKS - Cam Pulley - Duralumin
Nissan RB26DETT/RB25DE(T)/ All Duralum Slide, For exhaust side22004-AN002AU $ 147.141
Nissan RB26DETT/RB25DE(T) All Duralum / Slide, For inlet side (except for NVCS engine).22004-AN001AU $ 147.141
HKS - Camshafts - Nissan
To Suit BNR32,BCNR33,WGNC34, RB26DETT, EXHAUST 280 Degree, LIFT 10.20, STEP 2, These Cams must be installed with Upgraded Valve Springs (Item Code: 2201-RN014 ).2202-RN133AU $ 362.951
To Suit BNR32,BCNR33,WGNC34, RB26DETT, INLET 280 Degree, LIFT 10.20, STEP 2, These Cams must be installed with Upgraded Valve Springs (Item Code: 2201-RN014 )2202-RN132AU $ 362.951
HKS - Fine Tune Timing Belt
Nissan RB20DET, RB25DET, RB26DETT24999-AN001AU $ 137.936
HKS - Fuel Injectors
HKS 1000cc Top Fed Injector1402-RA002AU $ 1,063.991
HKS - Fuel Rail
To Suit GTR 11.0 (After market Injectors needed)1407-RN003AU $ 275.851
HKS - GT Turbine Stainless Exhaust Manifold
Nissan BNR32 RB26DETT, Flange Size GT25/SPL.R1419-RN004AU $ 2,550.271
HKS - Stroker Kit - Nissan RB26DETT - 2.8L Step 1, 2 & 3
HKS RB26DETT 2.8L STEP 3 882kW(1200ps)2104-RN006AU $ 8,944.981
HKS - Turbine - Suction Funnel
100mm Turbo Suction Funnel (Purple)1499-RA038AU $ 147.781
HKS - Turbine - T51
HKS T51R SPL BB 56T A/R 1.001401-RA145AU $ 3,383.431
HKS - V CAM System - Step 1 A & B
Nissan BNR32 RB26DETT Duration IN 248, Vlave Lift 8.6mm, Valve Timing 75 -125 degrees (HKS Pistons Kit needed)2007-AN003 STEP 1 Type BAU $ 4,264.851
HKS - Valve Guide
Nissan - RB26DETT - 1 set - Phosphorus Bronze - 0.5 Oversize2299-RN002AU $ 423.631
HKS - Valve Spring
To Suit RB26DETT STEP PRO CAMSHAFT2201-RN015AU $ 413.781
JUN - Surge Tank
Nissan RB26DETT Surge Tank2015M-N005AU $ 2,539.922
Nismo - Air Flow Meter
Nismo - AFM - RB2622680-RR580AU $ 724.111
Nismo - Engine Mounts
Nissan - Skyline - BNR32,BCNR33 Kit 2 X Front 1 X Mission11200-RS580AU $ 168.461
Nismo - GT LSD - Pro
Skyline BNR32,BNCR33 RB26DETT 1.5 Way38420-RSS15-EAU $ 993.061
Power Enterprise - Triple Plate Clutch
Nissan BNR32 RB26DETT 1000KG PullGTRAU $ 1,956.031
Splitfire - Super Direct Di ignition system
Nissan - Skyline - BNR32 - RB26DETTSF-DIS-001 IN STOCKAU $ 465.932
Tomei - Air Flow Meter - Adapter
Air Flow Meter adapter194002AU $ 44.781
Tomei - Gasket Combination - Nissan RB26DETT
Nissan RB26DETT Bore 87mm Thickness 1.2mm133013AU $ 343.331
Tomei - Oil Gallery Orifice
Nissan Skyline BNR32, BCNR33, BNR34 RB26DETT X 1 ONLY191071AU $ 8.741
Trust - Greddy - Intercooler SPEC-R HG / SPEC-R
Nissan Skyline BNR32 RB26DET 89/8-94/11 SPEC-R HG Type 25 H302/L600/W149mm 4 Layer (Radiator front)12020439 SKYLINEAU $ 1,716.171
Trust - Greddy - Oil Pan Upgrade Kit
Nissan RB26DETT Oil Pan Up Grade Kit13525900AU $ 310.14
Sub Total
AU $ 35,076.43
the list:-
HKS - Fuel Rail
HKS - Turbine - T51
HKS - Valve Guide
HKS - Valve Spring
JUN - Surge Tank
Sub Total
AU $ 35,076.43
Do you think the above order will "sneak through" customs without tax? :P
$15-20k will get you a JUN stroker and turbo(s) and good for 600awhp (or so I'm led to believe from my tuner) far more realistic than a 1000hp+ rb as outlined in the above posts the cost skyrockets much like that dyno graph
Do you think the above order will "sneak through" customs without tax? :D
hmm maybe if it gets delivered in like 100 small pacakges? :)
:D yeah about that "dyno graph"...: :P
i can get my son to draw me a graph and read 1500Hp@17000RPM :P
Also...There has been no mention of cost on fitting and extra bits and pieces you
will need..
Buy one already with HP....saves you lots of time and money
OH great list...but I think you forgot the Turbo's...or Turbo
the list:-
HKS - Fuel Rail
HKS - Turbine - T51
HKS - Valve Guide
HKS - Valve Spring
JUN - Surge Tank
Sub Total
AU $ 35,076.43
If anyone forwards this estimate to my wife (i.e. she learns the real cost of my build! ) I will personally hunt them down! :)
If anyone forwards this estimate to my wife (i.e. she learns the real cost of my build! ) I will personally hunt them down! :laugh:
that's the email address so i dont mistake her for someone else? :)
actually i was quite supprised to see that nengun can do the hks t51r spl for 3500 delivered!
But that is only the turbo itself. Add manifold and wastegate, dump and inlet. Possibly even oil and water lines.
That list has a lot of parts missing. Add shipping and some tax, then double the lot for an 80k+ budget.
jun stroker is about 9k + gst (so 10k),
n1 block 4-5k
nismo bearings $300,
jun oil pump $1200
n1 water pump $350
machining, etc $1000 (not assembly)
engine seals, core plugs and shit is like $200-300
cams $1100
head porting $2k
clutch 3k
twin 044 fuel pumps $500
intank pump $300
turbo $3k+
fuel rail $400
ecu $3-4k
bigger sump $1-2k
manifold 2k
head and main studs - ?
retainers ?
valve springs?
ati balancer $1k
exhuast
gearbox
thats a minimal list i could think of in 2 min so add about double that and u get a jun stroker setup done properly
just internals for head and bottom end, and block for mine is like 24k, thats without turbos, no ecu, no fuel system, no nuthin.
if i knew the costs i would of gone os giken 3l personally for that little bit extra
dont let anyone tell u a big build on a 26 (using stroker kit) is 10-15k because thats rubbish
Wow some of those lists are ridiculous. Haha some of those parts are not even needed. The arc radiator?? $1600.00?? thanks but no thanks a koyo radiator will do fine. The intercooler will be custom made by XS Engineering. Like i said the V-Cam would be one of the last upgrades so i really dont need that. Like ive said for the hundreth time the hks 2.8l step 3 kit IS NOT MY ONLY CHOICE hello the tomei one costs 5k and seems to be just as good. Lastly i do not want a HKS t51 turbine. If im going single turbo im getting a kit from Full-Race which comes with a twin scroll manifold so the bigger turbos like the GT40R, GT42R can spool up somewhat quicker. Also the jun surge tank rather get the Full-Race surge tank with the 102mm throttle body.
I would like to thank everyone for there time and knowledge i did learn a lot more about what it takes to make massive hp on an rb26dett. However as i said before the 350z project isnt going and if I was going to do it then i would have gone with a huge build up. My definte project is swapping the rb26dett w/rb25det into my s14. Ill just stick with the 2.6 and get aftermarket pistons and rods. Work the head. 600hp in a 2900lb rwd should be more than enough to fly on the highway and be a total sleeper. Thanks again.
p.s. saw that the prices for the nengun list where in AUD so im not sure how much that equates to the dollar.
u pay for quality :(
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
