The Q45 wount physically fit into the T30. The VQ35 on the other hand. Murano version will line up very well. I have looked over the wiring involved and its not to difficult depending what series T30 you have.
  • Replies 47
SEEING THAT THIS THREAD IS NOT GOING ANYWHERE....
I want one with a Turbo....is this possible...?
2003 late.....The drive train seems to be good...
I havent built a Turbo QR25 but I have seen it done, afar more common conversion is the SR20VE.
It must be at low boost then yeah...Or does the motor have low compression to start off with?
It sounds like a good upgrade...lower the thing and put some gtr rims on...sure it will be bling with the power.. :wave:
Im not sure what it was running finished, I only had a hand in the turbo selection which was a humble S15 T28.
They should handle the regular 8-10 psi with a well tunned ECU.
Design wise the bottom end is brilliant untill you get to the ridiculos balancing ideas
check this link for a crazy ozzie guy who has done a ta22 celica with a lexus 1uzfe turbo conversion and using full gtr driveline to make it 4wd :)
have a read its a huge huge project but would be awesome once finished.
http://www.toymods.net/forums/showthread.php?t=18227
thats gotta be one of the most insane projects ive ever read in my life, awesome piece of engineering work.
dont say anything is impossible after seeing that :laugh:
How bout you buy a complete GTR, and remove the whole chassis from under the body, unpicking the thousands of spot welds, so youre left with the complete drivetrain inc suspension.
Do the same to the Z and simply slide it under and reweld! Sure it might be different in trackwidth and length (no idea about that), but that can be taken care of with a quick cut and shut and some wheel offset.
Easy!
.....easier than making ATTESA fit into the Z chassis.
Forget using a Murano drivetrain. While its probably slightly better suited than an R3x GT-R's, it won't be by much.
For starters the engine mounted is the wrong way, and it only comes with a CVT transmission which are known to not handle that much torque. Almost doubling your horsepower without increasing your redline means you're adding almost double the torque, and that's probably going to munch a CVT.
Actually, if you want a manual AWD Nissan you're going to have to use a GT-R. I can't find a current manual AWD Nissan on the market.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
