So I had a nasty clunk, bottoming out and rattle from my front left of the car.
Took it down to pedders and got a 28 point inspection, they said it was the glange nut and tightened it with a metal bar (free) this fixed it but it'll probably come lose again (want $140 to take it out and tighten it). Now I've got a track day coming up in about 3 weeks and there was a few other things that were busted.
He reckons my ball joints are worn, however I took the wheels off and went crazy trying to move them around and couldn't get them to budge, so I'm a bit hesitant.
The radius bushes are worn and the rear sway bar link rubbers are worn (clunk a little). How major is this stuff (def getting the nut fixed up), he seemed to reckon fairly so but of course its his obligation to say so. Recommendations?
Pricing they wanted for everything.
Tighten glange nut $140
ball joints x2 $80-120
rear sway bar rubbers $50-60
bump stops (front were mangled and missing) $87
radius bushes $40-90
Edited by Rolls
what on earth is a glange nut?
anyway....looks like they're asking 450 to replace about 1/3 of your bushes with standard rubber stuff.
If you are interested in track work I reckon you should bit the bullet, spend twice as much and do everything in noltec or whiteline bushes. handling will be out of sight better.
I can't see anything dangerous on that list
[disclaimer]Don't blame me if you die from not taking the Pedders sales person's advice[/disclaimer]
Cause its not tight, apparently you cant get to it without taking it out, so they just smacked it with a metal bar or something, I dont really know what Im talking about thats just what they said,
Who would you recommend going to then.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
