Hi All,
Ever since I have owned my R33 the drivers side electric motor hasn't worked, and I noticed today that the de-fogging function on the glass doesn't work either. Passengers side is fine though..
Have had a look in the fusebox but it all seems in tact. Any ideas people?
:D
chicane
:burnout:
I had a look on the weekend, i can remove the mirror from the door, (pop off the plastic cover and undo the 3 screws), but how do i get in behind the plate glass? i tried popping it off but I didn't wanna bust the glass ;)
chicane, i have the same prob with my passanger side mirror which made a bad noise when folding out once then never folded out again... but still folds in, i just pull it out by hand, drivers side perfect. I've also tryed pulling it apart and got to the point where u are, ive been meaning to ask nissan for a look at the photos of it, also just curious about the mirror defogging, do you have a switch to turn this on ?
cheers...lenno
The mirror glass should just pop off - you have to kinda pull quite hard, but it does eventually come off...
There are several screws holding the motor unit in place, just undo them and then you should be able to remove the entire unit from the cover.
Dave, tnx for your reply.. I'll have another look tonight to see if I can pop it out..
Lenno, Probably suggest you do what Demon Dave has suggested, Have a look at the motor.. I'll take some pics with the digi cam may be able to help ya.
As for the defogging, I read in a Skyline Manual that when the rear demister is put on, the side mirrors have defogging built into them.. and just the rear demister button to the right of the hazard switch turns it on.. On a real cold/foggy morning if I park on my lawn, the side mirrors get fogged up - The passenger side one clears really quickly but the drivers side remains the same..
Cheers
Hi Lenno,
I have the manual in front of me at the moment: It's the JPNZ R33 Skyline Drivers Manual.. (mate lent it to me, was in his glovebox when he got the car). Page 57:
"Heated Mirrors & Rear Window De-Fogger"
The super sonic mirror will heat up to defog the mirrors. Push button, shown to operate super sonic option first mirror will vibrate to remove any water from the mirrors then heater will switch on. If mirror gets old and scratched and isnt working sufficiently contact nissan to have specified mirror replaced. Dont clean mirrors with an abrasive cleaning material"
also
Pg 51.
"Heated Door Mirror"
When the Rear De-Fogger is pressed the Heated Mirror System will automatically turn on to melt away any ice on the mirrors. This system will automatically turn itself offafter 15 minutes or you can press the Rear De-Fogger switch again to turn off the system manually. Do not try to use the Power Mirror Function while the mirrors have ice on them, always use the heated mirror system first."
Hope this helps!!
chicane
PS. I have a feeling the reason the mirror isnt working properly is because it was bodged by the compliance people when they changed it to a flat glass mirror.. Grrrrrrrrrr :)
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
