FMIC don't really give power.
Is your POD exposed or boxed up(enclosed)? If its exposed your probably losing power right here compared to a standard airbox because of the heat from the engine bay.
Power isn't everything take your car to the drag strip and see how it performs against other cars with the same or more power.
Its ONLY A dyno reading, its used for tuning get your powerfc in wack in more boost and tune it and you will get the results or thereabouts.
Just get the power fc in it, the stendard r&r is far more severe on the r34 than the r33. I dyno'd a stock r 34 gtt, then he went away and got a million dollar front mount, million dollar exhaust, and brought it back, gained 4 rwkw, and lost about 30 kw in the midrange. looked like a rollercoaster. How does your dyno graph look?This one had 2 or 3 skijumps instead of the usual one for a r33)
for 33's i disagree, I've heard people say 12psi through 33's stndard cooler but with my own s2 i found that bloody unlikely as mine was majorly miss behaving with the standard smic.
drop a free'ER flowing fmic and piping and walla...she stoped nock,backfiring an just drove like a frign dream.. after that.
I get a jjr split front an dump, this weekend, im putting in my widebody 3" catco with it on my 3" cat back and il let you all know what she's like @ 10psi
the stock maps scale up when inc boost, so is it a rising rate when inc boost so the car literally runs worse afr;s or they come down a bit ?
The afr's get heaps worse when upping the boost, even standard they can go off the scale(<10:1), and it just gets worse from there, the other major problem is that the computer pulls out heaps of timing which loses any powe gain you would have had.
184rwkw @ 9psi with boost dropping hard (midrange was at 13psi)
FMIC, Pod
Zorst with terrible cat (changed now, goes better)
Avcr (hate it)
Power FC
Somehow want to hold 14psi and make 200rwkw, we'll see if i can sort the boost dropping issues out.
Edited by jazza08
This is an r34 thread so this post is completely irrelevant and will only serve to confuse people who don't read carefully.
FMIC in r34's rare give any power. This much is true.
Dyno's do give very different read outs and are not comparable without controlled circumstances. For instnace, I went to Bel garage Mainline dyno one day and got 255rwkw, a month later on a similar day weather wise, with no other changes, I got 256rwkw on the Dyno Dynamics dyno at UAS.
Now if I went to Bel and got 255rwkw and you went to UAs and got 255rwkw I would not expect that they would have identical power until both cars had been on the other dynos.
ps. I now have 272rwkw on Unigroup's Dyno Dynamics dyno but got over 300rwkw on another dyno.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
