the new just jap kit is bolt on.. my ass it is..
on the other hand the hybrid kit is easier.
Today Chris and i set to work on fitting a just jap FMIC to his 1993 R33 S1 which i can safely say is one of the best S1 ive seen!.
Just Jap $345 FMIC kit
HKS T piece
76mm hole saw
angle grinder
first off
removing the Front bar. due to having a few extra hidden clips took a bit longer than expected..
removing the SMIC and pipping.
removing the front support.
then getting stuck as he had no instructions.. so i went searching on sau and found nothing.. thanks..
decided to wing it :laugh: and dummy fitted the cooler core. mounted on the bottom brackets.
dummy fit the front support. cut to fit.. fit then removed to cut for top brackets.
fit. then removed to drill new bracket holes.. would be nice if they told us..
then refit. used spacers..
fit LHS pipping.
drilled 76mm hole with tools supplied by TAFE QLD :no:
drilled one more. i did use R33S2 diagram thanks mate.. helpful seeing i had no instructions.
fit pipping. tightened.
start up.. the top pipe touched the fan. so re adjusted properly..
start perfect :down:
sprayed cut body with antirust.
attempted to fit front bar.
hacked rear of bar.
indicators wer in the way so hacked that.then resealed it with duck tape properly not dodgy like shane would.
fitted to front bar.
splash guards on. inner guards on.
retensioned all bolts, clamps and brackets. fitted all clamps to face the same way. to look pro..
went for a test drive..
saw 14PSI.. then had to plumb in the intercooler line.. ther is no nipple so i cut the vac line from TB and inserted a HKS T piece (HKS POWAH AND SPORTS). hooked up to solenoid and boost is at 9ish PSI.
had to rebend the top pipe to suit, rethread a clamp.
chris is happy with his FMIC i got paid and the world is at piece.. and he scored a HKS part..
your more than welcome chris and i hope u enjoy your stay on this forum. if u need anymore work im happy to do some more. but no more custom cutting.. and ill charge by the hour.. due to extra cutting it took around 4 hours.. :ninja: wher as the hybrid took me 2-3??
some happy shots taken by chris
thanks chris and thanks sau
mark.
https://www.sau.com.au/forums/topic/158803-demoniaks-new-fmic-basically-custom/
that took u 4 hours :huh:
i woulda looked at it, opened a beer, and said go elsewhere :)
as if im dodgy, says the man who uses bleed valves as a boost 'controller' :(
i still like manually controlling boost over electric.. something bout not having electronics that run on copper wires keeping ur car from hitting 45psi..
in addition to that, did u put rubber around the hole u cut for the cooler pipe?
ahaha NO shane i didnt.. want to knw why...? i cut a hole big enough to accomodate the cooler pipe with room to spare.. and left nothing touching anything..
i left 2mm gap from thermo to core, 3mm from rad fan without cutting it.. skills yo..
quite a fun day..
if u want ill build ur GTR for u.. ;) ...(the garden ornament)
Yep, I fitted my Hybrid FMIC Kit a couple weeks ago and was a piece of piss sept shaping the fan, i didnt expect that.
hey ryan
yeah i found the hybrid easier than the just jap.. the just jap which we used had too much bracket bending and no instructions.. but didnt need to shape and cut the fan as she clears it nicely.. 2-3mm.. only cause i did bend the top pipe mounting bracket to fit nicely. all in all looks professionaly done and keeps chris happy.. and looks stock too :)
put pics up of ur car chris.. how how its hidden nicely :(
What did you charge to install the FMIC Mark, I need my kit installed :D
he charged a very fair price.. i bought some of the tools and i was the lacky for the day ( did the easy side of the FMIC and helped where needed)
and yeah scored a fully sick HKS part...
Ill post some pics up of the baby once i have washed her.. shes pretty damn dirty atm.
But yeah id say it would be a solid 3-4 hour job ( take time off from us having a bit of a break and figuring out what to do etc)
It will hit.... I give you one week...
dont be like that..im sure it will be fine ;)
im keen to see how much extra powa i got now.. all i need is an exhuast system and the thing is breathing aftermarket style :D
i doubt that. i fastened it with 10mm bracket and lock nut. and the clamps are super tight.
ok col if it doesnt touch within a week u shout me dinner one tuesday night lol.. :D
yeah i didnt charge much as thought it was similar to hybrid but wasnt. but not one to go back on my word so all good. PM me if u want to get one fitted.. ;)
im off to drags now in the R34.. ;)
Gotta be careful bending those brackets that are welded to ally, I hope you held the bracket in a vice or something and bent after that.. whoever installed the fmic kit in my car didn't brace the bracket before bending and now the weld is starting to crack :wave: I have since unbolted the bracket in an attempt to slowdown the cracking O_o
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
