I got my r34 smic more for flow rather then cooling reasons.
everytime i pull over after a spirited run i feel both sides of the cooler
slightly warm on inlet side but just ambient temp out the outlet side
its not until i follow the pipes back up into the engine bay where
they start getting warm from the radiator fan blowing hot air directly at the pipes
i'll grab some heat wrap for that. eventually
SO,wouldnt fmic's cop more heat from the radiator fan as most fmic kits have the
piping which goes right across the fan.i believe that would suck for $400 + fitting.
  • Replies 46
While the rad fan might be blowing hot air over the pipe...its more likely the heat from the engine/turbo/exhaust manifold thats causing the pipes to heat up more...
Another solution for this will be to get a fmic with the inlet and outlet on the same side and use the standard pipes...such coolers are becoming more common nowadays and are very affordable...
yeh someone on here was looking into fabricating the end tank of a std/universal fmic
so the inlet and outlets are on the same side by putting in a divider in the
middle of the end tank to push the air across the face of the cooler.
this is the option i will be going for at a later date.
Heat soaked pod? Hahahaha...
Seriously...i can't believe some of the nonsense you're spewing...
Could you please explain why it could not be the pod?
because your post was nothing more than a waste of bandwidth if no reason is included :P
Note; the only time I have felt any symptoms was after a run + a 5min stop, so no doubt the exposed pod may have caused some problems once i started moving again, but then again i could be wrong :rofl:
We all learn from our mistakes but i dont remember me undermining you when you didnt believe the power gain from the smic... :thumbsup:
So either reply with a decent answer/explanation or dont bother replying at all as I dont want a mess in here.
After all we're all here to learn from experiences :)
On another note;
RSTME could share more information about your SMIC mod.
ie; any power gains, did you reweld or work with custom piping, did you attach airduct to smic etc
- Patrick
is it just me or are the afrs on both cars lean for stock ecu?
shouldnt it plummet down to 10s on max load after a while - typical stock ecu style ?
Unsure about these specific dyno graphs, but from my personal experience with stock ecu, it goes richeroony under load... right down to 8.
Ok...i do believe your gains with the 34 cooler...i have had my car a RE customs before and i believe your power outputs...personally its still not the path i would choose or have chosen...but that is my choice...as for your comment on a heat soaked pod...a pod cannot get heat soaked...the air snd pipes in your engine bay would be heat soaked though...along with the smic...however...once you start moving again for a short distance you will be getting slightly cooler air into the engine bay...so the so called "heat soaked pod" will be ok...but the heat soaked cooler will take awhile to cool down...
- Patrick
Sure,not sure exactly on power gains but thats why i opted for the r32smic...its cheap
and allows more flow..not necesary the cooling side of things.
i got the old outlet cut and shut and put onto the other side(backyard style)
the cooler does its job fine,its just when the air travels back up into the engine bay
where it cops heat from the RADIATOR FAN that causes the inlet temps to go back up after its
been through the smic.No air duct is used.i see the idea of it but it would intrude on my
air feed to the airbox.
im not quite sure about this heat soaked pod thing but when i had my pod i measured its
temp with one of those laser pointer temp readers and it was roughly 58degrees after a cruise to
wollongong. at the same time the dump pipe was 200+ degrees.
the only time i could imagine my smic getting heat soaked is if i was doing a line locker
which i wont do as my g/box is too precious.
p.s i ripped off the plastic inner guard thing so the air that cools the smic flows right on through
which in my opinion helps.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
