bonnets can end VERY badly. There was a thread not that long ago with someone very disappointed in the fitment of the bonnet (from a certain, c-mate). Can look very exy, and dangerous if cheap stuff... if twisted/bent slightly, can crack splinter, blah blah... take out pedestrians eyes, same old same old
