  • Replies 490
Posted Images
Allright, Group buy 10 is rolling, I have 3 confirmed orders:
- Fry_33 for R33 Gts-t front/rear
- dan.1337 for R32 Gts-t front
- djr81 for R32 GTR front/rear
Group buy 10 ending this Friday 25th May - so don't miss out!
Would it cost any more to have them drilled 4 and 5 stud PCD 114.3
Looking at r33 fronts and s14/s15 fronts in both varients.
Price for per pair delivered to perth 6027
Cheers
price please for r33 gtst front and rear, slotted. just want to know when will full payment be needed by so i can pull my finger out and get some new rotors
cheers eli
edit: also need postage to capalaba qld 4157
Edited by ELI
Cheers
YES it will. You will need to purchase one whole crate of 120 pieces of rotors. That cost a lot!
Sorry, no custom drilled allowed.
Cheers
Would i be able to get prices (delivered per pair) for the r33 fronts and s14/s15 fronts in both varients to perth 6027.
Thanks
n i'll just get them drilled 4 stud locally :)
I'm in and paid up for the R33 GTST Rotors F&R
Thanks Rianto
No problems, your payment has cleared...
Will organise all the orders this Friday...
Updated order list:
- k3 for S14 front/rear
Two more orders in tonight:
- SoFly for R32 Gtst front
- fluent for S13 2.0 front.
We have 6 people I will organise to submit this group buy tonight...
Can you also get group buy prices for EBC brake pads?
Looking into R32 gtst grooved/slotted rotors (front) + EBC greenstuff (front & rear)
Possible to get a cheap bundle price for the above setup?
As my pads are worn out and my rotors are undersized :stupid:
Thanks
Patrick
Hi mate, prices for front + rear rotors for the GT-T please. In both slotted and slotted+dimple version please.
I know you said theres no 310mm but would the 296mm for the R33 GTS-T fit the GTT fine?
Thanks,
Andy
Edited by Andi
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
