  • Replies 490
Posted Images
R34NRG, the R34 GTT rotors front are not yet available, there's been a delay with RDA stock... only rear ones available if you want it, otherwise if you want whole set will have to wait...
RDA don't do front disc's for GTT???? I just bought some fronts from DBA and they are great...kinda weird that RDA dont do them... SHAME
They are having them made at the moment, it's probably no one inquiried about them before (until I started the group buy here) so they haven't made any in the past.
I've talked to RDA and it should not be that 6-12 months long to wait, but it's been more than 3 months since they started to look into manufacturing them so if it is available in the next 3 months that would be about 6 months+ in total actually.
For the time being if anyone need ASAP then DBA is the only choice, otherwise go JDM and import something from japan. There's nothing wrong buying DBA, they're good rotors too.
Got a couple of guys misses out so I have taken more orders for a small Group Buy 23 to be submitted ASAP, please pm me if you want in ASAP, probably will submit batch 23 on Monday...
- gtstcoupe for R33 rotors (payment received)
- davieb for R32 rotors (payment clearing ASAP)
hey mate,
good to hear that RDA are plannning to make the rotors for the GTT.
i will be waiting for the rotors for the GTT anyways thanks and keep up the good work!
Edited by lcy
pm replied...
By the way batch 23 was started for those who missed out batch 22.
- gtstcoupe
- davieb
Your orders have been placed and has been shipped...
Will start Batch 24 now...
slotted Front and back for R33 GTS-T postage to 3037
chenx.
I hear slotted + dimpled rotor's are weaker then just slotted is this true?
PM sent...
I think you may have heard talk on cross drilled rotors cracking, but that's not the case with RDA dimpled rotors.
Conventional cross drilled rotors are known prone to cracking under hard use e.g. track/circuit.
that is because a lot of materials are removed from the rotor.
RDA did not cross drilled the rotors but they blind drilled them, therefore the strength can be maintained.
Therefore it is called dimpled, not drilled. So they should be a lot stronger than conventional cross drilled.
But regardless what rotors you have, once you take your rotors to the track, that will void all warranties
of any parts. Regardless what material or whether it's plain or slotted,e t c.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
