  • Replies 490
Posted Images
R34NRG, the R34 GTT rotors front are not yet available, there's been a delay with RDA stock... only rear ones available if you want it, otherwise if you want whole set will have to wait...
RDA don't do front disc's for GTT???? I just bought some fronts from DBA and they are great...kinda weird that RDA dont do them... SHAME
They are having them made at the moment, it's probably no one inquiried about them before (until I started the group buy here) so they haven't made any in the past.
I've talked to RDA and it should not be that 6-12 months long to wait, but it's been more than 3 months since they started to look into manufacturing them so if it is available in the next 3 months that would be about 6 months+ in total actually.
For the time being if anyone need ASAP then DBA is the only choice, otherwise go JDM and import something from japan. There's nothing wrong buying DBA, they're good rotors too.
Got a couple of guys misses out so I have taken more orders for a small Group Buy 23 to be submitted ASAP, please pm me if you want in ASAP, probably will submit batch 23 on Monday...
- gtstcoupe for R33 rotors (payment received)
- davieb for R32 rotors (payment clearing ASAP)
hey mate,
good to hear that RDA are plannning to make the rotors for the GTT.
i will be waiting for the rotors for the GTT anyways thanks and keep up the good work!
Edited by lcy
pm replied...
By the way batch 23 was started for those who missed out batch 22.
- gtstcoupe
- davieb
Your orders have been placed and has been shipped...
Will start Batch 24 now...
slotted Front and back for R33 GTS-T postage to 3037
chenx.
I hear slotted + dimpled rotor's are weaker then just slotted is this true?
PM sent...
I think you may have heard talk on cross drilled rotors cracking, but that's not the case with RDA dimpled rotors.
Conventional cross drilled rotors are known prone to cracking under hard use e.g. track/circuit.
that is because a lot of materials are removed from the rotor.
RDA did not cross drilled the rotors but they blind drilled them, therefore the strength can be maintained.
Therefore it is called dimpled, not drilled. So they should be a lot stronger than conventional cross drilled.
But regardless what rotors you have, once you take your rotors to the track, that will void all warranties
of any parts. Regardless what material or whether it's plain or slotted,e t c.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
