  • Replies 490
Posted Images
Quotes sent, updated Group Buy 25 orders received:
- WORK32GTR for rear R32 GTR rotors
- CHUNDA for front R32 Gtst rotors
- TURISMO for front R32 Gtst rotors
- bilbo117 for R33 gtst rotors & EBC greenpads
- mlt15e for R33 gtst grooved rotors
- kjb_r33 for R32 gtst rotors
- intouch for R32 gtst rotors (TBC)
i have a 32 gtst and need new disc's, was just wondering if i could buy r33 gtst rotors as an upgrade and not have to change anything else? If so can i get a price on:
x2 front slotted 33gtst rotors and x2 r32 gtst rear slotted rotors?
Ash, if you have a 32 Gtst you will need to get R32 rotors if you do not wish to change anything.
R32 rotors front is 280mm od while R33 is 296mm od, there's 16mm difference there or 8mm bigger on each side.
You need to check your clearance it'll probably hit your caliper or your brake pads position won't be in the optimum location.
The rear R32 & R33 gtst are both the same 297mm od.
If you want then I will suggest 2x front slotted R32 Gtst & 2x R32 gtst rear slotted, unless you want to custom make a caliper adapter to fit the R33 gtst rotors at the front.
Updated Group Buy 25 orders received:
1 WORK32GTR for rear R32 GTR rotors (payment received)
2 CHUNDA for front R32 Gtst rotors (payment received)
3 TURISMO for front R32 Gtst rotors (payment received)
4 bilbo117 for R33 gtst rotors & EBC greenpads (payment received)
5 mlt15e for R33 gtst grooved rotors (payment received)
6 BRUNSKIGTST for R32 gtst rotors (payment received)
7 kjb_r33 for R32 gtst rotors (payment received)
8 AdamD for R33 gtst grooved rotors (payment received)
9 tuitahi for R33 gtst rotors (payment received)
Update: 7 orders confirmed (payment received), just waiting on the other two...
Group Buy Closes tomorrow!
GROUP BUY 25 CLOSED...
Orders to be submitted only those with payment has cleared:
Got mine today, THANKS. Should have actually been yesterday but i wasnt home when TNT called. Have left feedback
Edited by kjb_r33
Hey there.
Keen on Slotted R34 GTT fronts and rears on the next group if in stock.
GT-Passage, R34 front GT-T not yet in stock but I will keep checking with RDA.
It's been a while I'm not 100% why the delay is however I think it's gotta be available anytime this year.
Stolen_S15, I have started group buy 2008 in the group buy section, click the link in my signature...
  • 1 month later...
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
