  • Replies 665
exact dates please guys :)
I need to book time off
edit - and we need stickers made up before also.... *looks over at Corinnnnnnnne* :)
Im pretty sure its August 25th??
Yeah How much Corinne?? I want them on my car now :)
so who wants stickers?
me
Corinne
Nick - intune
Stephan?
Steve?
Jess
Andrew?
beer baron?
TJ?
anyone else????
Corinne is making them soon, need numbers y0!
Chubbs you can be the numbers keeper so i can have them all together. put both Jess & I down for 2, put in how many you want?
me
Corinne
Nick - intune
Stephan?
Steve?
Jess
Andrew?
beer baron?
TJ?
anyone else????
Meh!! :)
I am defecting to Team Wang!! :bunny:
Only because I have two balls and im not afraid to used them :P
Someone from Vic sent me some Team Wang stickers!! :(
Meh!! :)
Only because I have two balls and im not afraid to used them :(
Woops.. thats right your not good enough to be in Team BTR!
dam you smokey
dam you!!!!
Actually, I'll have two Corinne, r31 and r33 :P
Where did you want to put them?
meh, I've been team wang for long time. It's not all that. BTR is way better. no doubt.
corrine, I'll take a BTR sticker. better put johnny down for one too. and waye and ron probably too.
and please tell me talk is spelt t a l k? :O
and please tell me talk is spelt t a l k? :)
So 4?
Where do you guys want them?
Haha sif spell it that way..
Its torque! It sounds much cooler :O
hopefully these wont be too expencive!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
