mate just brough an xr6t and while probably quicker, it doesnt feel as violent when shifting through gears (and comming on boost). so it had quiet a smooth power delivery compared to my line. only having around 170rwkws mine certianly feels like its going harder but im sure it aint.. ;)
Edited by jake33
https://www.sau.com.au/forums/topic/159201-r33-vs-xr6t/#findComment-2954915
IIRC the XR6T has a 14.1 sec stock quarter mile time and the R33 has a 14.4.
But then you have to realize that your comparing an 18k car to a 35k car. Likewise the XR6T is newer, and should have alot better tech crammed into it and less K's on the clock. 4L vs 2.5L. Large curb weight vs medium curb weight. 4 door vs 2 door. Auto vs manual.
At the end of the day, its still a Ford and thats why it loses.
(at least in my opinion)
FYI, http://www.skylinesaustralia.com/forums/in...showtopic=80479
https://www.sau.com.au/forums/topic/159201-r33-vs-xr6t/#findComment-2955319
zoom did a tech article on the xr6t. they took the centre muffler out and gained 17kw, and it was still well under the legal sound rating.
stock for stock i'd say the xr6t would beat a gts-t or gtt skyline. and if you start modding them to a point where you start changing ecu's then the xr6t will hose a gts-t/gtt. just by remapping the stock xr6t ecu they can gain up to 100hp (remember that these cars were detuned to have less power than the v8's. there were a few cars recalled because they had a 300kw tune in the ecu - which is what ford was orginally going to run them at). there is one in town tat has just had exhaust, flash tune and boosted up to about 11psi and it put down 390hp (290kw). there are also guys with reasonably stock typhoons getting high 11's. they just do airbox and exhaust mods.
https://www.sau.com.au/forums/topic/159201-r33-vs-xr6t/#findComment-2956423
my sister-in-law's boyfriend has a xr6t. i was sitting at the end of the street in the rain 1 day and he came off the roundabout and up the hill. he didn't floor it but gave it a little bit of gas and the traction control kicked in for a second. that sounds cool. its like having a rev limiter kick in when the exhaust note is at its deepest. was the best sounding limiter type noise i have heard, cause it wasn't screaming, it was nice and throaty.
https://www.sau.com.au/forums/topic/159201-r33-vs-xr6t/#findComment-2956599
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
