Hi, first I have an RB25 fuel rail with six Sard 550cc injectors. Was removed from the same running car. Comes with injector loom as well. NOW $500 ono. SOLD!
Lastly, i have a set of Rays Nismo 17inch wheels and tyres, suit Skyline and Silvia 5 stud.
Fronts are 17x8inch with 235 Falken tyres, 50% tread with a little camber wear.
Rears are 17x9inch with 255 Kumho Ecsta tyres, 60% tread.
The offsets are +35 front and +38 rear.
A couple of rims have small gutter marks about 2cm long, and they need a good polish. Paint is peeling a little on centres.
Also comes with wheelnuts. $750
Items are in Liverpool NSW area for picking up, or can post computer or injectors at buyers cost.
Contact Tim via PM or can Email me [email protected]
Edited by StoopidFlanders
https://www.sau.com.au/forums/topic/159523-sold-sold-sold-please-remove/
How long where the injectors in the car for?
Hi, dont actually know how many k's they've done as i didnt own the car they came from. i found a receipt in the glovebox of the car though, they were fitted by C&V Performance in Sydney in 2004. They cost the owner $1500!
There are no kms reading on it. The injectors look clean inside the tips but thats all the info i have sorry.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
