The best thread for how to join the club and any questions is the sticky in NSW, http://www.skylinesaustralia.com/forums/sh...ead.php?t=44115.
Members are welcome from all over the state, and we have quite a few interstate members too. While it may be difficult to get to events as most are Sydney or surrounding area (yes often including Newcastle/Hunter), you still get the benefits of:
Supporting the NSW Skyline club
Access to the members only forum
Access to CAMs licenses and events
Access to a range of club sponsors
  • Replies 98
The best thread for how to join the club and any questions is the sticky in NSW' date=' http://www.skylinesaustralia.com/forums/sh...ead.php?t=44115.
Thanks Duncan, thats what we have been looking for. i know I am new here, but how about posting this link on the main page so other new members can fine it without to much effort. Cause you know we don't do searchs very well. And we need to be babied as much as possible.
Just my .022 cents worth , gst inclusive :wassup:
Thanks Duncan' date=' thats what we have been looking for. i know I am new here, but how about posting this link on the main page so other new members can fine it without to much effort. Cause you know we don't do searchs very well. And we need to be babied as much as possible.
Just my .022 cents worth , gst inclusive :wassup:[/quote']
Glad to see interest in the club. :D
Sorry if the forms been a little hard to find. We've only had that thread a sticky on the main NSW page since 22/6/04. :)
If you guys have any questions just belt off a PM to:
Me, Majanal, Duncan, Shell, PranK or our membership guru Aurora.
Thanks Duncan.
I am now awaiting approval of membership O_o
I've got the form today so its on its way thru the system...prolly 2-4 weeks...but thats no reason not to come along to stuff in the meantime
  • 4 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
When I lived in Sydney and owned a Morgan, I was a member of that Club for many years. I probably took part in just about every event of whatever type that was run. If I lived in or reasonably close to Sydney, 2 hours or so, I'd probably do the same with this Club. Have you, or will you consider a 'Country Membership Fee Structure' to make it more practical for us out-of-towners who really can't join in at all?
I will bring it up at the next meeting.
  • 4 months later...
i havnt joined yet cos i wanna c what the events r like i was spec at one drag day an im currently waitin for nov 5th drag day an run down the run way :) if all gose well on drag day will anyone there b able 2 take my cash an form insted of sendin it away so i can join there an then ???
  • 4 weeks later...
Hey, y'all!! I'm Tul. I can not be the member of this club because now i''m in Bangkok, Thailand but in the future i'm gonna migrate to Aus and maybe live in NSW. Can i join this awesome club before the real? .....Thanks.
Edited by aussie_tul
  • 3 months later...
  • 3 months later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
