Hey guys i have a r33 skyline, its my second r33, mods are
Power FC
rebuilt forged pistons
pod filter,
JustSR metal intake pipe,
FMIC
walbro pump
boost 10psi
bov
Now had my power fc tuned car feels great.
only thing when i am in secdon then accelerate full throttle it feels flat and the car is not breaking tracktion or any hint of it.
Now my last r33 wiht stock ecu would almost break tracktion if i did this.
If i fast change full tgrottle to second it will wheel spin. Or is i puck the cluck then dump second it rockets off.
Its got me thinking maybe when i just put my foot down it uses a different point of the mpa so can be tuned out?
ANy one have any ecperiecnce with what i mean?
Edited by tmc_2
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/
Sounds to me that its not tuned properly. change your fuel filter and plugs and gap them to .8.
You really need to get a wide band air fuel ratio meter on it and check how it is running to fix these kinda problems.
IF you wanted to try adding 4deg of timing over all and see if it changes the situation at all - check the power fc faq it should tell you how to do it in there from memory you go to settings then ign/inj then change the timing to +4 (remember that every time you turn the car off this setting gets reset back to 0)
if its heaps better then you need to really put a wide band on it and retune the whole ecu
ALSO what size are the wheels on your car? and what size were they on the old car? bigger wheels make the car feel doggy - dont forget that.
what compression ratio is the engine ?? do a compression test and tell me what the reading is.
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2965440
Thanks Guily-Toy.
I don tknow the compression ration of the engine sorry, im assuming its standard comp.
I have 18/235 wheels previously had 17/245 on 1st r33.
i tried 1degree (i know stuff all) of advance timming over whole map, made maybe small difference and knock did not increase at all. I will try more timming tonight and see how that goes.
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2969927
Its retarded in that particular section of the map. Poor tune really.
You will find whoever has tunned it probably did the cruise/high load stuff and didn't bother to get the rest of the map sweet.
Do a map trace and drive the car around for 15mins. You will find the majority of cells have been tagged. It can only take a small section of the map to be way wrong and the general feel of the car turns to crap.
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2969984
tyres/suspension would be a far more governing factor there.
Im with Cubes here
I had over 250rwkw and never had traction issues.
With a stock ECU i wouldnt even think a car would be breaking traction unless the tyres fitted were just below par
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2971099
I know tryre/suspenson will effect this.
I dont mean break traction as wheel spin, more so when u plant on it in second it will rocket off and u will feel the tyres slightly breaking traction then griping. Or when i am turning into a street and u give it say 1/2-2/3 throttle the last r33 would break tracktion. This one doesnt.
I am guessing it feels like that point in the map is not tuned the best.
AHID i will take u up on that offer if i havent had it to the work shop by then :worship:
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2971539
Quite possible your old diff was opening wheeling a touch then.
Especially if it would break traction/chirping and not step the arse end out at all.
As said.. in second especially an r33 with those mods shouldn't be chirping the tyres as it accelerates. I don't mean chirp when you change gear but a constant chirp chirp chirp chirp as you accelerate. Road surface also makes a massive difference to grip.
R31Nismoid a mate since he fitted new tyres (nankang ns2's lol) it generally doesn't break traction in second gear with his rb30det gt35r gts4 (in RWD mode) making 270rwkw. Well some times depending on road surface it will ever so slightly spin towards the end of second gear at around 5500-6000rpm but regardless thats making close to 200rwkw at 4000rpm so if anything that should break traction.
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2971554
Pretty similar to what mine was like :worship:
Only the very top end of 2nd or 3rd
https://www.sau.com.au/forums/topic/159682-pwer-fc-tuners/#findComment-2971613
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
