usually takes a fair whack of power to turn the starter.
sometimes if you get a flat battery that is drained enough, it doesn't even have enough power to throw out the solenoid in the starter to engage it... (the clicking noise with a 'normal' flat battery)
we get it all the time at work (i work in roadside assistance) where people say "but all the lights on the dash/headlights/etc are working, the engine just won't crank" - 99.99% of the time it is a flat battery.
https://www.sau.com.au/forums/topic/159939-car-wont-start/#findComment-2970011
I pray your'e right. Thanks for the reply bro.
https://www.sau.com.au/forums/topic/159939-car-wont-start/#findComment-2970050
Mine was doing this (sometimes turned over and started instantly) sometimes all it did was 'click' and nothing.
Turns out mine was worn out terminal contacts at the starter motor due to low voltage cranking.
So check battery first to see if it is just an 'almost dead' battery, then move onto the starter motor, including all connections to starter and battery.
A 'relay' was added to my starter to help with the low voltage to starter (although I don't think this was the ultimate solution). I'm going to, when I get the time, replace the positive and negative cables (battery -'ve to block, etc) because I'm thinking my car has a low voltage problem altogether due to poor condition, and size, of these cables. The -'ve cable to the block and negative battery terminal itself looks greasy/dirty and is of small size.
Fixxxer :worship:
https://www.sau.com.au/forums/topic/159939-car-wont-start/#findComment-2971346
usually an alarm won't stop it from cranking though....
what? nearly every immobiliser I know if disables the starter motor... it's usually one of the 3 points of 'cut'. fuel, spark, starter.
https://www.sau.com.au/forums/topic/159939-car-wont-start/#findComment-2973992
If it turns out it wasnt your alarm your starter motor could be cactus. Check that its not your battery by turning on the headlights onto something, so you can see them and if they go out when you try to crank your motor then its your battery. if they stay on and only dim a little then its your starter motor...dont know much about the alarms so i hope this helps :nyaanyaa:
https://www.sau.com.au/forums/topic/159939-car-wont-start/#findComment-2974281
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
