well drag warz has been run and won.
theo took out sport rwd, finally some final action for him, and some low nines as well which if i am correct he backed up and should have lowered the et record and also the MPH record.
was great to see team berzerky out there with a good 5 or 6 car team in the class, all there guys did really well. i must also say publicly thankyou to you guys for your sportsmanship in the semi when you realised i had an issue getting the cressida to crank over. its great to see, its a shame others in the sport arent like it.
we were really happy with our performance on the day even with a slipping auto we still ran a pb of 10.008 et at 139.99 mph and on another pass went 143.32 mph. once the box is sorted at its current level of tune i am confident of a 9.8 et. then we will progressively wind the boost into it and see what it can do.
i didnt get to see mark run but his car sounded strong all day long.
cheers
shane
https://www.sau.com.au/forums/topic/159982-drag-warz/
Not much of a crowd at all. Not very well publicised but we still had fun. Had a good day even though we broke the car :)
Was great to catch up with a bunch of guys I only ever see at Sport Compact events esp the Cressida guys. Big thank you to the Bezerkly Automotive team who had more cars there than just about any other shop and managed a couple of runner-up positions for the first timers!
Awesome stuff!
https://www.sau.com.au/forums/topic/159982-drag-warz/#findComment-2970545
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
