from the research I have done it seems pretty uncommon to damage the engine when an exaust turbine drops off.
sure if your doing 200ks and on the redline + engine cough it could make its way through all the piping and into the engine.... but it'd be pretty rare I'm tipping.
reason why I am waiting is because when a terb blows I'll be doing the entire head and manifold system and putting it on my stock bottom end until its blows >_<
if you want to speak to someone who had to rebuild due to a turbo failure, pm Duncan. his turbo actually sucked up a washer which chopped and damaged his bored etc. its unlikely that you would need a rebuild after an exhaust wheel failure. a compressor wheel failure is a complete different story. you'd just need to hope the fins in your fmic caught everything.
take your intercooler and hoses off and see if there is any scratching in them. that would be an indicator to whether or not it was compressor failure.
I wouldn't wait if I was you, you're playing with death. That was my attitude... but the thought that potentially my engine is now rooted due to ceramic shards is a bad feeling. But I'm also a tad excited about the forced upgrade - if that turns out to be required.
To those mechanics out there who have seen many blown up gtrs - what percentage of them would you say have done an engine as a result of the turbo? I know it happens - but is it rare?
Very common....Supras too
After you noticed it did you back off straight away, or were you still accelerating? If backed off straight away (no good).
I have a feeling your engine is fine. I think all the noise your hearing is the comp wheel hitting against the cover.
Well the chases are if you have older stock or upgraded turbos and they are getting some Km's on them there is every chance that a wheel/bearing has failed in the turbo.
I have had my engine completly destroyed and a mate of mine has had the same thing on a 20,000 km old R34 vspec. This happens all to easy and a bit of extra boost then the wheel falls of....... then shit happens :ermm:
I had after market steel wheel turbos and the bearing let go which then wheel hit the housing and it was all over in a cold of smoke...!
The turbo then enters back through the to the head and bore through the velocity of the wheel and the shattering particals then following the curve of the housing and manifold through to the head.
It does not seam to make much difference on the throttle postion reving the car up or down, it is rpm of the wheel and the volcity of the bits.
If comp test ok.... some new snails and off you go... :sorcerer:
We've started dismantling the whole setup, and as you'd expect in the world most cramped engine bay, everything is a pain in the arse.
Firstly, yes I found the exhaust wheel sitting right where you'd expect it in front of the cat. See photos. The majority of the actual blades seem to have disintegrated, where I don't know yet - hopefully straight through the cat and out the exhaust pipe.
Next we started pulling the intake pipes off only to discover a hell of a lot of oil lining the pipes along with a substantial amount of mud!!! Well fine dust embedded in the oil. That's not good. See pic.
Once all the piping was off we discovered the oil and water lines. Shouldn't be too hard to get that out of the way - WRONG! The bolts for the water lines will not move - they just won't. Firstly the nut seems a wired size, but after much stuffing around found a spanner that was a pretty good fit. No matter how much muscle was put in, it wouldn't budge. Even a dirty great big pipe on the end of the spanner wouldn't do. See pic with red circle for what I'm talking about. The only way forward is to completely bugger something, or for someone to produce some exotic tool to get it off... and that's just the first one of about five, they're all tight as hell.. and I don't see how you'd get the ones going into the turbo off, they are at such a bad angle to get a spanner on.
I'm sure plenty of people have faced this situation while getting at gtr turbos - anyone care to share some wisdom?
Edited by cash0
The best way to get that line off is with a decent PIPE spanner. Snap-on make the best pipe spanners as they dont spread open and round the bolt/nut head. You can interlock the pipe spanner with another ring spanner for extra length and torque. Thats not the wors't of it yet mate, plenty more instal for you my friend... enjoy!
^^ Do you have a pic of this pipe spanner??? I am helping cash0 with this...
Another thing to think about cash0 is:
Will any of this water piping be needed with your replacment turbos. Ie, are you going to have to run braded oil and water lines anyway, like if you went for a big single. If thats the case we dont have to worrie about damaging them too much...
SK suggested having a sticky beak inside the zaust mainfold as thats the path that the ceramic would go towards your values and through to your cylinders. I think this is the safest thing to do before we turn it over again.
Ps, just spoke to will. He saw you on the side of mugga when it happened :P
Ps, just spoke to will. He saw you on the side of mugga when it happened :)
Certainly. This is a pic of a snap-on pipe spanner, disigned for such situations as this. Here is another pic of how to interlock thy pipe spanner. :sorcerer:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
