Hi guys received my hybrid fmic kit today and going to install it with a mate. Read all the threads to do with the install but got 2 questions even after reading them all.
What do you use to cut the fan blades if needed?
Everyone mentions that you need to screw in a nipple for the boost. I am running factory boost...do i still need to do this or is that only for aftermarket boost controller?
any help asap would be great
cheers
https://www.sau.com.au/forums/topic/160639-front-mount-install-help/
i used the same kit on my 32, to trim the blades i used a stanley knife/box cutter whatever you want to call it to trim just the corner of the blades that come in contact with the pipe, assuming its for a 33 should still only be a couple of centimteres at most. as for the nipple thing, i didnt do it on mine but then again i am under the impression that only 33's have to do it... hope that helps
Small version of a hack saw works, but before you start hacking into it make template out of paper and apply the template to each blade with a nikko. Once these are cut neaten it up emery paper.
You will see on the stock return piping (the side with the BOV on it) there is a nipple that goes to the boost solenoid, if your FMIC kit has an identical nipple here you won't have to put one in. How ever if there isn't go down to Repco and get a nipple the same diameter as the stock and tap it into the new intercooler piping about where the stock one was.
Yes, you need the nipple, even for stock boost.
You're running stock boost now and your using the nipple.
FMIC makes no difference, it's still needed.
The pressure feed from the nipple to the wastegate makes the wategate open to let out excess exhaust gasses keeping the boost low at 7psi.
If you don't have that feed (ie, no nipple) your boost WILL keep going up in excess of 1bar (14psi) and eventually loose blades out the back and into the Cat.
** Get the nipple **
May as well do it while it's not installed, should be pretty easy.
There's a discussion about that too somewhere
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
