Hey fellow Queenslanders,
Just got myself a R34 2 weeks ago, took some pics today.
Extremly stock. not a thing done to it and very clean. Very happy with my purchase. Imported from Japan.
it even just had a standard tape deck.... btw for sale. stock tape deck. rare. dolby stero, $300 :blink:
The tape deck was the first thing that had to go. So I replaced it with a pioneer DEH-P9850BT.
The compliancers even left the xenons in for me :P .
Im located on the Sunny Coast, but drive down to brisbane a lot for work.
Here are some pics
it even just had a standard tape deck.... btw for sale. stock tape deck. rare. dolby stero, $300 :thumbsup:
The compliancers even left the xenons in for me :) .
Here are some pics
i think i saw you about 3 on gympie rd.
nice ride
cheers
edit: same like urs butt with wing
Edited by naomy
Hey all...just became a skyliner the other week...R34GT (slow) 4 door (making it slower)
fully stock minus the heavy tint, exhaust, and lowering on 19inch advanti's...
Planning to follow 666dans steps into throwing in a turbine one day (waiting for more $)
Nice to see lotta 'liners on the southside....
-xcalibre
Hi all
New to the world of SAU
Owned a couple of skylines before, recently a R33 GTR V Spec and years ago a r31 silhouette.
I pickup my new toy next week, a black 32 GTR (can't wait)
Hope to see you cruising around
Also where does everyone meetup these days?
In Brisbane that is
Hi all
In Brisbane that is
hey mick, welcome to the forum mate. 32 Gtrs all the way! haha. What part of brisbane you from? Every now and then people organise a dinner, cruise or track meet and so on in the Event forum. Keep an eye in there. Enjoy your stay
Hey hojak I'm on the westside and I'll keep an eye on the event forum
Would like to put a face to the car so to speak
I see so many crusing around and wonder if their on these forums
Any pics of your 32?
Go the 32 GTRs
Go the 32 GTRs
I'll show you mine if you show me yours... :laugh:
Was taken at a little meet we recently had last saturday.
Hi all,
:rofl:
I drive a 2003 M35 Stagea 250T RS four, mainly to and from work.... Sthsde Brissy always up for a burn an turn so if you see a reeeeally quick "Volvo" looking car shooting past, that could be me. i dont kno if anyone else owns one around here??? always keen for a drive and to go to any events an stuff around Bris vegas so invites welcome.
2003 Nissan Stagea with high flo turbo just installed, im looking now at wheels, exhaust, Sat Nav conversion, lowering, so if anyone knows a cool mob to help out please let me know as i have no idea what im doing!!
and how the hell do you get the TV to work....
Cheers
G
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
