ok looking at a new fuel pump, the walbro is cheaper but it says allows similar flow rates the bosch costs more what is the diffrence? i would like to eventually run up to 300hp@ the rear wheels running about 220atm.
any help would be nice. I also searched and couldnt find much else on this.
thanks!
https://www.sau.com.au/forums/topic/161186-bosch-vs-walbro/
I am yet to go for my full tune (before i need a rebuild no doubt). after my FMIC are on, my injectors and Z32 AFM are installed, an after I get a Haltech E11 ecu ill let you know. dont hold ur breath lol. The current mods I have are a turbo back 5 zigen/custom dump exhaust system 3.25 inch. GT3076R turbo @ 12-13psi (16 psi once) on a Turbosmart boost T. and some wierd ecu that doesnt rich and retard on me.
Performance as far as I can tell has been good, even better after i mounted it lower into my tank to suck past 1/4 of a tank to empty. (i installed it myself).
https://www.sau.com.au/forums/topic/161186-bosch-vs-walbro/#findComment-2993137
i got a Bosch 023. mounted it myself.. took a few attempts to get it as close to the bottom of the tank with out it touching. and never had any dramas with 1/4 surging. would recommend the bosch over the walbro for piece of mind. purely and simply
plus there not that much more. picked mine up for 219 delivered
https://www.sau.com.au/forums/topic/161186-bosch-vs-walbro/#findComment-2993508
I've used a walbro in the past. Ran 195 rwkw no probs. Now run a 040 which i think is muchbetter. I asked a workshop why do you dislike the walbro and was given the response well have you ever seen a bosch 040 and a walbro side by side the walbro is half the size if not smaller, so how could it perform the same as the bosch!
Edited by mickr33
https://www.sau.com.au/forums/topic/161186-bosch-vs-walbro/#findComment-2993737
i have a WALBROW GSS342 mine pushing 217 rwKs on a standard setup engine. Works well no issues there. Theer are cheep walbrows and bosh pumps. Just make sure that you get the pumps form propper dealers and you should have no issues.
I have used walbrow before on several cars, and no probs, but i have had 2 bosh pumps die before, not 040 though.
https://www.sau.com.au/forums/topic/161186-bosch-vs-walbro/#findComment-2994016
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
