  • Replies 88
Posted Images
thx.engine mod wise, that I know of fmic, oil cooler, oil filter relocator kit, earthing kit, cams, z32 afm, rb25 hi flowed turbo. Last dyno put out 172 awkws with a t piece in it no boost controller, not real happy with that figure. Need to get it dynoed again and sorted, now I have a boost controller In. Want to have it sorted properly.
  • 4 weeks later...
Well have the car back. Match is not 100%, looks good from some viewpoints, but not as good in others. Spraypainter hates my car, the color is very hard to match, may be taking it back in a week or so to finetune it, as place I took it to said they'd be playing around a bit with some different color cards. Either way I think I'm gonna start saving for a full respray perhaps, as the rest of the paint isn't in the best shape anyway, will probably need to get a new lip for it to as the one that came with it isn't too great, need to see if I can finetune the front bar fitment too.
thx, I still blame you and your pics lol, gtr bar does set the car off nicely. Still need to fine tune fitment of the bar as well.
Well took some pics this arvo after going to the hardware store for some screws etc to mount my number plate (slim line is on my list of things to buy)
Tooks some more pics, with the lip now on. Color match looks good in some angles and shit in others, it is a bastard that way lol
does feel a bit ridiculous how low the front lip is, lol. Still troubleshooting my headlight clips, and now debating whether to put the gtr grill on or not.
If you can, defantly put the grill in. I dont know why but a set of work XD9's in black would look motherf**kingPORN. See if you can get a photoshop?
XD9's with a lil bit more slamage and gtr grill..... :(:spank: nuff said
Thx I'm working on the gtr grill :P , just my headlights are driving me up the wall, had a look at the xd9's and the colour reminds me too much of my old rims lol. That and the fact I'm on my 3rd set of rims, doesn't make me want to get some new ones atm lol. Will probably keep it at the same height too, as it was bottoming out before I had it raised an inch.
Next on the list is to get the car re dynoed, and them maybe some other light mechanical mods. After that respray probably, idk. way down the line.
Probably getting the front bar resprayed again as well, just not sure atm.
  • 3 weeks later...
Hey Chris,
What bonnet pins did you use?
Could I get a closer pic of them?
my GTR bonnet has holes for the generic type of bonnet pin.. I bought an aerocatch bonnet pin but didnt like the look.
Cheers mate
Edited by GTS4WD
  • 5 weeks later...
Yeah looks good from further away lol :cheers: . Sort of decided now to spend a bit more money on finetuning the performance, but apart from that leaving it alone as much as possible, and getting some more motorsport events done.
In the long run If I still have the car in a few years, which I'm planning to, It'll get a full respray, car will need some work to fix all the panel gap issues. Don't really know anyone in the industry to save me money
Looks like my car had a bit of a hard life in japan, even though it drives straight, the panel gaps are shit.
  • 3 weeks later...
well f**k me, found the japanese for sale add for my car, cars changed a bit, but I now know where my catch can went
http://yamayagroup.co.jp/5606hnr32.htm and my km reading wasn't set at 152000 km when i got it, still a while off on my revised odometer... :P
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
