Na, doesn't damage it too much (it will do damage if you just leaving it sitting on the limiter for ages). It happens because the rev limiter works by cutting fuel, which causes the afr's to momentarily lean out. The PFC reading only measures the maximum knock, average knock would be a much more useful reading here.
https://www.sau.com.au/forums/topic/161250--/#findComment-2994117
average knock is 10- 15, never goes above that no matter how hard i drive, this is the 1st time its been this high and i didn't sit on the limiter, only hit it and engine light flashed, got me all paranoid. but when i revvied to just before rev limiter a few times after knock was 10 - 15 the whole way to 7000rpm, i set rev limiter at 7200, so its never revved too hard. thing is i've hit rev limiter before and its never got that much knock before, thats why i got worried
Edited by scarface
https://www.sau.com.au/forums/topic/161250--/#findComment-2994145
Even if the car did have a big detionation, its still running fine so i wouldn't be worried about it.
I had knock of 152 once... i think i got a stone in the engine bay hahahah
You only need to worry if knock is going above 40+ like everytime you drive, then you'd need the tune looked at, under 15 is very safe, tuned fairly softly :wave:
https://www.sau.com.au/forums/topic/161250--/#findComment-2994247
    • I like they don't raise their hands into the air when they shift their sequential boxes, seems to be a thing here in Australia lol...
    • I'm not normally one for posting random videos, but I thought we'd all appreciate the honesty about how broken our cars tend to be lol. Genuine skyline life here.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
