Well now I have done the Ultimate Trim 'leather' interior, I thought it was time to make a custom gauge panel for the spare DIN spot in the R34, put in some of 666dans blue leds into the dash cluster, and cut out the ash tray and integrate the SAFCII into the dash.
I plan to go a little bit more crazy with the carbon fibre, and may well re-do the bits I have done as some of it is a bit rough and better techniques would give a better result.
I thought I'd share these photos for your enjoyment.
I will get some better photos in daylight today also.
https://www.sau.com.au/forums/topic/161278-my-little-interior-project/
Thanks guys. Like I said I am going to make some small improvements but am quite happy with it overall. The device on the top right is an M350, which is a digital speedo with 0-400m, power reading, lap times etc, but I haven't figured out the Japanese instructions to get it all working yet.
I haven't actually got the Hybrid solenoid hooked up yet - it is wired through to the engine bay, but I haven't had time to plug it all in. I used the older model of this one and it was very good - so I expect this one to be as good if not better.
The dash lights take under an hour to install. The hardest part is getting the cluster out - it is a p.i.t.a if you don't remove the steering wheel (like I didn't).
Andrew what does the p.i.t.a stand for?
And Paul. i think the HP gains with just the interior the way it is now is massive. like adds 98rwkw with just these mods itself. LOL Jokes.
It looks really good Andrew. Figuring out what to do to my interior to make it look more pretty.
Edited by R32_4door_drifting
hahahahahaha beat me to it :(
Thanks Brenton :ninja:
and Pauly, the Hybrid won't actually add any power, it will just make boost come on earlier, stronger and more controlled. I have also bought an HKS actuator which I will fit with my new turbo that will aid this also.
yeah Joel it is is just the $40 per roll carbon fibre contact style stuff from Autobarn. I actually wrapped it around the edges and stuck in under the trim, but will re-do it with the edged trimmed to the edge of the trim rather than folding under - I am sure it will look better that way, and be less prone to bubbles and ripples like it has now.
come up good Andrew, cutting it should stop it from bubbling. Have to find my self saw real carbon fibre i had a roll a while back but it ended up "dissolving" and you end up with black carbon hand prints every where after handling the stuff
yes, real carbon fibre would be nice! There is a mob in the Eastern states somewhere that can paint items to look and feel like carbon fibre, but from memory they were up to $100 per trim piece. Since I am going to do the whole vertical centre console, plus the power window surround thingo, it is too much $$$. I will try different techniques with the carbon contact and see how it goes.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
