Leather R32 & Cefiro Gear & Hand Brake Boots Group Buy
pablo101,
I've sent the money via EFT. However I'm unable to send you a PM but am able to receive PMs from you. Is there an email address at which I can contact you in order to send my mailing details? If not a telephone number will also do.
Cheers,
Gerard.
  • Replies 373
Posted Images
Hey man, I am interested but I understand that I missed out on this group buy. Let me know as soon as your ready for another group buy or if you have a set left over.
Cheers.
Hey Pablo, can I get the name of the people you're buying off? I'm actually on holidays in the UK at the moment and wouldn't mind checking them out. I already have new boots for my car, but if they do custom leather I might get the parcel shelf done or just see what they can do. PM me or post here if you could. Thanks.
Good news, they were at my door step today when I got home from Uni, and express posted them as quickly as possible (took a while to fill in all those addresses though!), it was 4pm so hopefully the AusPost truck had not picked up the daily mail already.
Should arrive tomorrow, if not Friday for those of you outside express post area codes.
+1!!!!!!!!!!!!!!!!
This group buy is currently filled. However if members fail to pay by Friday 13th, items will be sent to those members on the back up list (PM me to be on back up list). PM me if you are interested so I can see if there is enough people to start group buy Number 2
still awaiting payment from:
BLAQ.BOI
HR-32
please pay soon or your boots will be sent to other members
Edited by pablo101
Because so many people missed out on the last group buy, I have made group buy number two.
R32 boots group buy number 2 is now open. Once we have ten members the order will be put through, so be quick!
I hope we get our 10 members signing up for this. As soon as these arrive the interior mods on my skyline can start and I will get around to installing the stereo :O
COME ON PEOPLE.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
