So you're still keeping the airflow output map on greddy sensor when doing all this right? and doing all the clamping there and not even using the boost limiter map?
no the airflow output map was still throttle position vs rpm.
i was using the boost limiter map but for some reason it wasnt working.
Hmm not had this issue, i would try juggling the afm voltage in the output map to mid way between the two, bit on the rich side at idle say 12.5-13 instead of 14 ish and see if you can get enough cold start in there. without playing with it here it is a bit hard sorry.
ok i'll try putting the idle voltage somewhere around 1.35v and +20 to -20 which will give me 40% to play with. i should have thought of that sooner. thanks Trent, i'll let you know how i go.
  • Replies 765
What are you using to to tune the injector and/or ignition maps after the clamp? Greddy pressure or still throttle postion vs. RPM?
I'm sorry maybe you've posted this info already..... i have read this whole thread (took a week) but I dont remember if you have or not.
Edited by antomx
best to use pressure sensor. better resolution... gm sensor works fine to and cheaper.
yeah mate im using the pressure sensor for everything else.
its just cleaner to make the car run on the MAP sensor if you log the AFM voltages vs. throttle position.
Sorry for a very basic question I think but I dont really know much about mapping and am looking at E-Manage Ultimate as an option.
My S1 RB25DET had been converted to a wasted spark setup like this
Same kit
and I was wondering if this affects the ability to wire it in etc ?
Many thanks
Paul
Same kit
Many thanks
Paul
no stress, but yeah you need to follow the wasted spark diagram in the installation book
  • 1 month later...
I was just wondering if someone would be kindly enough to send me there map for:
rb25det s1
"emanage blue"
Stock Turbo
Stock Injectors
FMIC
POD
FULL Exhaust
looking to run about 13-14psi
i've just purchased a Blue emanage and have full access to a dyno
Though i will be looking to take it to trent afterwards for some fine tuning
I have the cable for the Emanage blue but having trouble tracking down the software for it
hopefully someone can be nice enough to send me the software also
[email protected]
Cheers
  • 1 month later...
This is the injector map of my EMU.
I dont know a thing about what these numbers mean really but my car is stareting to run like SH!T!
Getting alot of soot on the back now and cant run full boost without pinging.
Full is 15psi low is 10.5 runs on low boost but stinks of fuel when ever I pullup.
Does this map look normal?
Hi,
Just two quick questions about these ECU's. Is there anyway to reset them to a 'stock' map(i.e makes no alterations to signals).
Also will I be able to put in bigger injectors and Z32 AFM and make some quick adjustments myself so I can drive it to the tuner? It looks as simple as selecting the correct AFM, and then setting the old injector size, new injector size and timing. Is this correct and will I be able to drive on this safely or is there more too it?
Cheers,
Adrian
no you should be able to set those two things (assuming you have set it for the right car ) and drive to your tuner
i drove around for ages before taking it to the tuner
although I had a wideband and was able to tune the non load points so it wasnt rich as
just dont boost it hard and you should be fine
  • 4 weeks later...
Hi all. im kinda rooke in this area but have some quiestions that u guys might be able to answer. i have my emu hooked up with the plug in loom. car starts fine but it gets way to much fuel, the sparkplugs are very black, thou not wet.
I have set the correct parameters of the injectors as seen on the printscreens in the beginning of this thread. there seems to be some sort of problem cause if i set it at say 370cc and lagtime @ 0.71 at before and then changes to 850cc with a lagtime of 0.85 the car starts goes up a little in rev and then dies.
When setting both before and after to the same so it says 850 on both and same lagtime tha car runs better but still get isnae much fuel.
does make any difference if i put in 370cc onboth places either.
When taking the rev up to ~2000 rpms and letting of the gas the car stays on 2000 for a little moment and then goes down. very unresposive and runs poorly.
Any Ideas on what i can have done wrong?
Greatful for answers!
The car has those specs.
R33 gts-t
Topmount exhaust manifold.
Garret gt32 turbo
Greddystyle intake manifold.
Fmic
3" from turbo
Sard 850cc sidefeed injectors
sard progressive FPR with clock
Hks mushroom filter
Dave i still have not recieved your map, still happy to have a look over it.
[email protected]
Cheers Trent
Is there any reason or workaround for me not being able to get the car running more than 2 seconds when i put 370cc on "before" and 850 on "after" parameters in I/J settings?
If i set them to the same numbers in both before and after column it starts and runs decent.
best bet is to forget the numbers and concentrate on the results ie actual lambda. move the injector setting to say 650 then play with the lag times (0.5 - 0.9). Some injectors require thinking way outside the norm and the only way to set it up is by trial and error... bit of a bummer.
Edited by URAS
  • 1 month later...
hey trent,
the check engine light came on today on my R34 neo.
i got the tuner to install the unit + the neo ignition chip as well.
any reason why this would by happening?
car isn't miss firing or anything and is still running as normal.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
