Hey all I'm considering getting a Power FC and a set of Adjustable cam gears for my R32 GTR and was wondering what kind of power gain will I get from that. The car currently is making 240 rwkw on 14psi. It has N1 turbo's and cams. Also approx how much would I be paying for the power FC and hand controller.
So the ecu is remapped?
Must be. Sorry havn't really had a chance to have a good play around with the car since I've had it and it's sad cause I've had it for 4 yrs now and done all of 9000km it, So I'm only really going on what the guy I bought it off of told me.
Yer either way.. The PFC is the next step if you want to try keep up with Andrew. :)
I can't wait to get home and check that thing out. I think i'll go ahead and get a Power FC I'd love to get it up around the 300 mark that would keep me happy for a while.
As soon as you see 300rwk's budjet for a new clutch. LOL
power fc is definetly worth it . Go for the jetro if you can. Mine went from 199rwk's to 185rwks with mods, and power fc added and tuned 260rwk's. I make 292rwk's now with 1.1bar with N1 turbos. You should see aleast that power level because I still have standard injectors. good luck.
Sorry not knowing much about these what is the jetro and what are the difference's????
main diff with the D Jetro to std PFC is it uses MAP sensors and removes your AFM
just incase you dont know... MAP = Manifold Absolute Pressure and AFM = Air Flow Meter
RellikZephyr
Edited by RellikZephyr
292rwkw's on standard gtr injectors? do you have a fuel pressure regulator? what dyno was this on?
Edited by mr_rbman
Ash,
They 'should' do it with around 43-45psi base pressure and close to 100% duty. 43.5psi they flow 520cc's & 40psi 480cc's. Well mine did so yours will be no different.
I'm unsure if the GTR's as standard run a slightly higher base fuel pressure.
Did 292rwk's on peter halls dyno. Have seen them do 299rwk's on tilbrooks dyno but was running a bit lean .
As cubes said though , getting very close to full duty. As far as the pressure , unsure.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
