Has anyone attempted to adjust their Series 2 electronic speedo ? mines about 10% out.
Is it adjusted through a trimpot in the instrument cluster or by changing the pinion gear in the sender ?
Why is it 10% out? Have you changed the tyre diameter?
D Cheers :P
  • 1 year later...
Just for prosperity's sake... my S2 is exactly 10% out too; reads 10km/h above what I'm doing (verified by GPS etc) at 60 and above. I have the standard tyre profile of 205/55/16 and brand new tyres. I'm going to fit the Jaycar speedo corrector kit - thanks for the verification that it works on S2 Chook! Which wire is it??? I would like to trace it without removing dash if at all possible...
i didnt have any trouble finding it, perhaps it is written on the back of the instrument cluster i think, and you can trace it to the plug and harness from there. If you still cant find it, send me a PM and ill pull cluster out and let you know.
Jaycar was bit confusing to set up, but havnt had to worry about it since, works great.
i think it is variable in 1% increments
Correct! Got mine today; two adjustments which can be used simultaneously, one varies by 1% per step, the other by 10% per step. I say 'varies' because it can be set to alter the speed UP or DOWN (ie. faster or slower). I agree with you Chook there are heaps of options...
I'll try to take some pics as I proceed. What I would like to do though, is install this in the passenger side kick panel, where I can splice it right into the correct wire near the ECU, rather than pull my dash apart and try to fit it in there. Can anybody think of any problems with this approach?
I have been looking at the pinouts of the R34 ECU (found here: R34 ECU pinouts) though and I can't seem to find a speedo output? Only "Vehicle speed sensor signal (Vehicle speed sensor 2) - pin 29" plus there is a "Output shaft rotation sensor signal (Vehicle speed sensor 1) - pin 58" however that is just for automatics (which mine is) and both those pins appear to be inputs, not the ECU output to the speedo?
Chook can you remember the colour code of the wire you had to interrupt to install your kit? I might be able to trace it at the back of the ECU and save some other people some dash-removing hassles...
Edited by DaveB
1 Problem: I think the speed sensor goes to dash first, then from dash to ecu, (or perhaps 2 independant wires) so either way, you would have to intercept before dash to change your speedo, at ECU will not change speedo.
Ill check dash wire soon
OK, 30min later, SPEED SIGNAL is BLACK with WHITE stripe, goes into the single row plug above the temp gauge on back of cluster. Just intercept it about 15cm back from cluster.
I checked some information about the V35/M35 speed signal and the signal is transmitted form the VDC/TCS/ABS control unit and received by the Combination meters and then re-transmitted by the Combination Meters (Dash Cluster) to the ECM (Engine Control) and the TCM (Transmission control) as well as the BCM (Body control). IF you were to correct the signal for the speedo you would have to do it before the speedo but who know how this will affect the operation of the ECM & TCM with a modified signal.
I dont know why the speed signal is out it doesnt make sense. Probably the easiest way to correct the signal is with larger diameter wheels (~3% greater diameter)
I can confirm the the M35 has the same problem.
Thanks Chook that's quick work! :laugh:
interesting... your m35 is a generation later (V35/M35) than S2 Stagea (R34), but I wonder how much they changed it for consult II etc? I notice on autos the transmission speed sensor appears to be on a different pin ("Output shaft rotation sensor signal (Vehicle speed sensor 1) - pin 58"); but your info does explain why I can't find a speedo output on the ECU; there apparently isn't one! damn. If only it were that easy...
Correcting with oversized tyres isn't always easy, and is expensive; could the rule of thumb that "if the speedo guage can understand the speedo signal and display correctly, the gearbox, ECM, BCM etc. must be able to" apply? I hope so... i don't like the idea of playing around with all those systems. I wonder what difference it might have if they were calibrated at the factory on the original spec' (10% high) speed sensor output? Although I'm hoping it's just a pretty basic signal that the kit will reproduce accurately. I mean I guess most cars that this kit is designed to be used with (ie. those with digital speedos) would have these other modern systems as well? There is a warning in the instructions about airbag precautions, so they must surely know *something* about it... I hope... ;)
OK guys done some further investigation of the wiring diagrams Mike posted up for the R34, and it appears as though the only time the signal is passed on (well, I have to treat the combination meter as a 'black box' and assume the signal is actually modified in some way by it) by the combination meter is to the TCM (Traction Control Module), however this is apparrently only present on rear-wheel-drive models.
I would hazard a guess that this signal could be modified with some degree of safety, since if you modify it for one circuit (the combination meters) you modify it for all circuits thereafter (assuming that it is a simple signal which the speedo correction unit is able to reproduce accurately, and that you have it setup properly, however the way to guage this should be to simply adjust things until the speedo is working as before).
This speedo correction kit specifically says 'handles AC output for Nissan cars', or something similar, which I thought was interesting.
So thanks Chook, I might have a hunt for that wire (black with white stripe) at the ECU...
DaveB
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
