**r32** Skyline 300 Km/h Speedometer Cluster Kits - $100 Delivered
Which colour would people prefer?
101 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
ok so you've seen the R33 white face 300 km/h speedometer kits.
I will be doing a kit for the R32s but only if there is enough interest. Please post a reply to this thread ONLY if you would buy one of these kits. also select which colour you would prefer the faces to be, white or stock black.
the kit also includes 5 blue or red LEDs for an extra $30.
  • Replies 60
unless you can also get to suit r32 gtr, i would prefer black so i can add it into my stock cluster
is there a difference between the R32 GTST and GTR clusters?
I want one for my R32 GTS-T
By the way, any pics mate?
Cheers
have a look in the R33 300 km/h speedometer kit thread. I have modelled these closely to the stock R33 gauges, the R32 gauges will be similar to stock as well.
Put me down for a BLACK kit for a R32 GTR. Do teh 5 leds do the whole dash? If so put me down for them aswell.
Josh
White with Blue LEDs
so far I am seeing that the R32 GTR will be the most popular choice. however it's still neck and neck between black and white face dials.
I would need about 30 definates before I can go ahead and get these kits made up.
So you won't be doing an R32 GTST version?
maybe I will do both GTR and GTST versions :D but will need a lot more interest than that expressed so far to even get this happening.
maybe I will do both GTR and GTST versions :) but will need a lot more interest than that expressed so far to even get this happening.
YEAH BUDDIE I WILL HAVE A WHITE R32 GTST...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
