I got my silver E shape c/f bonnet from autobarn up south for my r33 it cost me 1300 with a 3 day wait for it to turn up from jet speed in qld.Also dont go to autobarn at mile end as they dont have insurance on products when you order them.
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3008306
I got my carbon fibre bonnet from speed dreams and paid about $1250 from memory. Technically they are illegal from any police point of view, altho you will have less troubles if you make sure that none of the vents are forward facing, cos that for sure is illegal according to regency, which of course is crap consider our locally made coonadore is made with twin forward facing vents....go figure!
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3008956
i thought that they were only illegal if the outside edges of the bonnet wasnt wider than the a-pillars, so in a crash if the bonnet is pushed back they slide up the a-pillars insted of going through the window and doing a bad things to the driver. wrx's have forward facing scoops to?? wtf. but i thought that it was rear facing vents were illigeal for the reason if oil spits up and out it will go over the window. i dont car i just want a nice 1! the look tuf!
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3009187
They are illegal due to something to do with the factor of them in a crash.
Vents are illegal if they chop the panel reinforcing inner, if they dont they must have mesh fitted to stop fingers going in. They can face anyway.
Cops will defect on sight, regardless if they are illegal or not. Painting them is a waste as the wank factor of having a cf is to show it off in the first place.
The r32 gtr bonnet weighs the same anyway, and is aluminium as u know.
The best place to get one is to stand outside regency and wait for someone to come through whose sick of being defected and wants to get rid of it fast. How many cars do u see normally driving around with one? Theres a reason :laugh:
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3009406
As Bl4ck32 said.
In an accident they shatter and can/ will go through the windscreen slicing anything in it's path.
Get a GTR bonnet. and if u really want the CF look get the contact that andrew got for his interior and roll it all over the gtr bonnet.
There ya go lightweight gtr bonnet with wank factor of the cf contact. HAHAHAH best of both worlds.
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3009423
A carbon fibre bonnet doesnt have any suports to cut as its a one peice mould, your more refering to putting a vent onto an existing bonnet.
Either way, before i bought my bonnet i rang regency and the basic explanation i got was that any vents should be made of the same material as the bonnet and that you couldnt have any forward facing vents. I told them i was looking at a carbon fibre bonnet and no comment was made to the bonnet being illegal, they did however mention bonnet pins being illegal, so you have to buy a bonnet with the correct catch moulded in.
Just what i got told, not saying its gospel, if you ring regency it seems to depend on who you get to speak to as to what answer you get!
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3009516
thats what i was referring to.
Take that as being illegal.
https://www.sau.com.au/forums/topic/161962-carbon-bonnets/#findComment-3009794
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
