I loved my GTI-R they are temperamental but no more than a GTR. They are OLD so like any old performance car anything that has not been replaced or rebuilt could die if pushed but having said that the engine is awesome, way over engineered (like a GTR). The engine is almost completely different to any other sr20det, solid lifters, quad throttles, different cams. I’m pretty sure even the rods and crank are beefier. The gearbox is strong but requires a bit of mechanical sympathy, there is a theory that most breakages are because the hardening wears of the teeth of the gears? Uprated gearsets are a $5k exercise. Handling out of the box is crap but can easily be corrected, around town they are unreal. They are stable at high speeds but noisy as and the doors try to peel them selves off at really high speeds. The looks are a bit love it or hate it but a good set of 16’s or 17’s are a must and chrome is a no no (but each to their own). Brakes are no good for track work but good rotors and pads are fine for the street. Filter, exhaust, heat range 7 platinum plugs and 1.1bar of boost saw 194kw atw at AVO which was enough for plenty of fun.
You must get a good one or you are looking at a world of pain. They aren’t cheap but very worth while, I still wish I had never sold mine.
Ok guys i was a previous owner of a 90 model gtir....I regret selling the car...even though i had done 2 clutches and 2 gearboxes.Eventually i purchased a 500hp synchro gearset out off par engineering in sydney and all the gearbox problems dissapeared..The car made 180 kwat4w and ran 12.9@165kwat4w before extra mods.Small car feels like your flying when you put your foot down.......ahhhhhhhh i miss my gtir...Today im in a 95 model gtr and married so i respect the drive where i loved being single and throwing that gtir around like a toy..
PRICK to work on!!!! I guarantee if anything that goes wrong is a bitch to fix....wait theres no word to describe how bad they are really....
Try to even get a visual on the starter motor let alone get it out! The engineering behind the car is ridiculous, but also a fantastic work of art i think. And pretty good to drive, although i think it has a really weird kinda upright seating position, but ok once u get used to it.
Easily understeers too, needs alot of money spent on suspension to get it nice.
Try to buy a good condition one and will save you headaches. Gearbox noise will shit you up the wall if it has any, which is most likely.
GL! Baby GTRs FTW!!!
Just want to know Gti-r any good and are they worth the money, i would prefer to hear from those who are currently own or previously own.
I think that's what he's saying.
I just want to know if Gti-r's are any good and if they are worth the money, I would prefer to hear from those who currently own or have previously owned one.
I think this is what both of you are trying to say :sick:
Edited by akeenan
I had a 90 GTiR prior to the r32 GTR, and the GTiR's r really nice/fast cars. Yep, understeer like a barstard with stock suspension. Gearbox's dont like abuse (mine held together just fine from 80K to 110k - written off - with near stock power (exhaust/pod). Damn expensive to fix when compared to purchase price. People have achieved 200Kw @ wheels with stock turbo (FC and other mods) but you would probably need a new turbo or a really fresh car to achieve this. I had an exhaust knocked up with no dramas. 3" stainless. I do miss that car!
Cheers, Sandy
ease up adz i was half pissed wen i started the topic plus i dropped out of school, thanks heaps for the info guys, like i said not gettin another car for at least 6 months, but good to no wat cars r like
Someone needs to keep you kids in line now Uncle Golgo is busy. Hey I failed English once but I still know you spell "when" with an "H". I was just taking the p|ss mate :sick:
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
