I was offered a bonnet vent on the weekend and initially I dismissed the idea out of hand, but I thought about it a bit more and it does make sense for a boosted car to get some of the excess heat out. Has anyone here done it and what sort of vent did you use?
I don't think I will use the one I was offered (butt ugly) but if I did do it, where abouts would be the best place to put it?
Also, if anyone has any photo's of the underside of a bonnet with the noise blanket removed I would love to see them.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/
yep carbon fibre FTW!
unfortunately there is no way the finances will stretch that far, besides, with my cars complete lack of aero, including the std front lip, I think it would look plain silly. I am really chasing function over form here, but at the same time I dont want it to look like I was a honda owner in a previous life :dry:
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011942
you dont need your car for us to know that. he he.
umm you could just find a simple vent. then get a panel beater to mould it into the bonnet. not hard for someone with knowhow.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011963
*biatch slaps the pommy car driver*
I was actually a card carrying certified trevmobile driver....
still got half a wardrobe full of Ford apparell.
I know this won't be hard, but I want to figure out the best place to put it with out having to cut through braces etc.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011999
well my fav bonnet for the stag is the one made by Masa, and Masa also state that the cars engine temps drop by 10deg using their bonnet, pitty its like over a grand shipped to my door and unfortunately i have way more important things to buy before a bonnet
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3013050
I know my carbon fibre bonnet on my 32 makes a world of difference to the temp it runs at, especially on a warm day with the air con on!
You could go drift spec and put spacers on the back edge of the bonnet to raise it slightly to allow some more airflow! Would be more legal too, cos i know the po po arent a fan of my bonnet! :rofl:
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3015368
Hrm, completely stock wagon with NO aero at all, with a drift spec raised bonnet rear....
Nah that wouldn't look wanky AT ALL! I might go and get some "V-Tec Yo" stickers when I pick up the spacers...:rofl:
Picsorban
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3015550
very very noice! :happy:
the police hassle you about that bonnet? I would have thought they would pay more attention to the wing, but...*shrug*
I was more thinking about just putting in something along the lines of the 2 vents on either side.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3016049
dont forget you can get those vents that sorta dip INTO the bonnet rather than sitting proud of the bonnet line.
We have not taken delivery of our stagea yet but I think its got some pretty nice lines completely un modified.
IF you go fora vent just get something with a fairly low profile and get it mounted nice and tidy, the last time I Got a vent fixed up he used something like a glue to mould it onto the Bonnet.. looked the goods!
maybe ask around and get someone to do a photoshop for you?
good luck matey!
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3018276
Remember vents cannot face backwards either, it is not legal. Always make sure if you install vents that they face forwards.
I believe this is in case the engine kerplodes, and oil sprays everywhere it won't shoot straight onto the windscreen and blind the driver.
That may be a myth, but you still can't have rearward facing vents.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3019698
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
