  • Replies 132
forum geeks??
me??
hahaha
Sorry mate, but I have under 200rwkw and I'll run rings around you! :happy: (Andru)
Seriously though man, ok, to hit over 260?
a GT3540
and a Z32 AFM or the nissan V8 AFM?
But still, Id be looking at internals to keep that engine alive for longer period of time.
And even then, you can still make 280 plus rwkw
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3016816
forum geeks??
me??
hahaha
a GT3540
3540 is way to big for the rb25 to make 300rwkw
hell my HKS 3040 is a tad too big for what i get and be nice and streetable.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3016828
oops
my mistake
so what would you say to use then?
(ECR033 - Brendan makes around 280 rwkw on this combination and ran a high 11)
What if you decided to use the RB30 bottom head? Obviously thats out of the question here but "theoretically" (sp?)
I think "MILF" the VL turbo has that combination and makes similar power
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3016840
GT35/40 FTW.. you'll make well over 300rwkw with reasonable boost, that answers the "what's needed" question. But as everyone has stated, don't bother chasing that power and beyond unless you're willing to spend $$$$ to build the engine with forged internals + all the supporting fuel, cooling, breathing mods.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3016849
oops
my mistake
Hey Chris,
Small correction mate - I'm using a GT3040R at the moment :happy:
To keep the car streetable, I personally wouldn't go for anything larger than a GT30 series on a std rb25.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3016898
im not to fused bout turbo size i know what im after, its just all the screwing around for everything to keep up with the turbo. its a hard job but im gonna give it a go.
how long will the car last with stock internals with 300rwkw. if possible id rather slap the turbo on now with the fuel pump and injectors, and when i get enough money put in the pistons, rods, ect
will it do alot of dmg or anything if im running 300kws with stock internals
Edited by anDru
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3017027
i always thouught of maybe buying a whole new engine and doing a engine swap, makes sense and might actually be cheaper, but like i said, i hate that whole engine surgery crap
Edited by anDru
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3017043
lol mate my car atm is 220rwkws......i know all u forum geeks think im some noob but take it easi lol....
i dont even think highflowing my turbo would even get anymore then 260rwkws, any suggestions on at least hitting 280? without all that engine sugeryy
lets see, if your aim is around 280rwkw then GT3040 with cams would do the trick. anything bigger will be laggy. and obviously other auxiliary components such as afm, fmic & etc will be needed.
as for injectors, 600cc would be sufficient for what you want to achieve.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3017047
really? thats not a bad option then, i just hope wat u say is true, i think i would defiently need pistons though :happy:
Edited by anDru
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3017104
A mate has an r33 with this setup (r34 would get similar result) almost 290rwkw if i remember correctly. Cams are the important factor here much better mid range power, more driveable.
Regarding longevity, if you track the car with 280rwkw the stock engine will let go sooner than later, if you mainly using it on the street then it should be fine as long as you treat it with care.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/2/#findComment-3017151
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
