I was driving in the speed limit slow as a nanna,pulled in near a restaurant to get food,, and then the familiar blue lights came on.
Cop pulled me over, and he said my r34 Style wing didnt go with my car's bodyline, previous cops were ok with it cause it wasnt aluminium just fibreglass but i guess im just plain unlucky this time.(p.s who wants to buy it,ill trade for a GTR wing)
The other thing he said was my exhaust,,he said no one's gonna give me permits for my exhaust. (big exhaust tips are a cop magnet peeps)
One interesting note is the officer said that he reads the Rollaboyz webpage,so i guess he's reading my thread right now and having a laugh.
I have a feeling even tho u have permits,it doesnt matter,,theyll just find something else that u dont have a permit for and sticker you anyway.They definitely have an "operation" with modded cars,so be careful guys and gals.
Yea by owning a performance vehicle,u have to live with the constant harrassment,dont worry bout me :D ill get the sticker off,no dramas at all.I can say im used to the yellow stickers, dont let a cop bring down your spirits to tune your car..never ever
The Defect Master
https://www.sau.com.au/forums/topic/16226-defect-master/
  • Replies 48
so u got another one???
did u tell them u just got it passed a week ago :D and theres nothing wrong with your wing!!
aghh oh well glad my car is mostly stock cos this is harrassment what they are doing to u guys!!
https://www.sau.com.au/forums/topic/16226-defect-master/#findComment-331912
damn and i feel really really bad about all this coz i has earlier on asked aidwin to come and say hi at the park where we were playing soccer coz i wanted to check out his new front bar
after chatting he left to grab some dinner and he ended up getting yellow stickered and its been on my mind the whole time that its partly my fault
:D:(
https://www.sau.com.au/forums/topic/16226-defect-master/#findComment-332146
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
