  • Replies 368
Is there any chance of doing a little date adjustment on this so it doesn't clash with the DECA event? :pirate: purdy please. :ph34r: As we now have quite a few people heading down south who I'm sure if they were able to go to this they would be entering. (me included!)
about half a dozen cars so far I think. I know it's a bit gay and selfish but perhaps we could go one week forward or back? of those half dozen going so far I would say 4 or so would probably be entering the DD if they could. I will. :pirate:
hell i'll even bring 2 skylines to the dyno day and pay to run them both! :ph34r:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
