Hey Joeyz, they won't necesarily tinker with the car. There's generally no time.
Unless it's Ben that's running the cars up, and your name is Mona, and you say, "I don't care what it gets just make sure I beat wilch!"
Then you make close to 500rwkW with a tiny turbo.
lol
^^ That was quite amusing last time when mona ran VERY HIGH numbers.. all in the turbo!!..
Should be a good day, looking forward to it..
LMAO!!!!! that was funny as hell!!! it made everyone do the double take!!! :D bens a top bloke! didn't think he'd go for the idea!! awesome stuff :)
  • Replies 368
2rismo i thought that a smaller wheel would improve the power output. dont think it will be worth it though. What kind of impact does fuel have on output? has anyone tried running different types of fuel?
also can u use nos on a dyno? that would be crazy....
Sorry all I have Some bad news, I have to head up the coast on friday night and I wont be back for the dyno day.
Sorry, but at least someone else will get a shot at the STD R33 gtst award I was chasing.
:dry:
Does it matter what time you turn up to Dyno day
I wont be there till after lunch and want to put my car on.....
.....couldnt see why that would be a problem !
- ive never been to a dyno day - i think im going to to go & have a look & say hi to everyone - should be fun im sure !! :)
yeah true :(
Awesome would be nice to see you again....
Malcolmmmmm!
Long time no see! You should come out more with everyone! :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
