  • Replies 368
Ok i have to get some gearbox oil so i'm in spectating tomorrow =)
its alright michael wouldn't want my beast to flog ya anyway lol. It would be very embarrasing beaton by a 4 door :O
BTW: I won't be there but Jason is taking my car.
Thanks for the great day guys and gals. Nice to meet you and thanks to the organisers for preparing a well turned out day.
Anyway here's some pics for you, although I'm not too happy at how they turned out.
My apologies for not being able to take pics of all the cars, I was a bit lazy :P and alot of cars were parked in bad positions to photograph.
yes, thanks to Ben+John+Tim+Andrew and Tim's girlfriend + Jess + Adam + Nick for running such a good dyno day. absolutely massive turnout of cars. It must be a record for an SAU/UAS dyno day?
well done. :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
