hey since i've owned the car i've noticed it's bloody hard to throw the car from 2nd back into 1st. it's nice and smooth when the car at a complete standstill but if i'm doing 20k's or more i seriously have to force it in and it feels like it's catching on something that i have to push thru. any ideas? cheers.
https://www.sau.com.au/forums/topic/162460-stiff-gear-shift-32gtr/
yes i have an idea don't shift back to first ever, unless you are at a complete standstill
really, whoever taught you to drive should have told you this. it's hard to put in as there are no synchros there. i'll say it again just to be sure. NEVER DOWNSHIFT TO FIRST. select first only from a complete standstill.
Hey,
In an R32 GTR manual, CH-31 and 32 clearly shows a baulk ring (what we call a synchro) on first... in this
photo from my box rebuild, it's the rightmost brassy ring on the top LHS shaft (mainshaft).
No comment on the don't-shift-to-first - I've shifted to first in-motion in every hillclimb
I've ever done - but that of course isn't normal driving :huh::laugh: Beer Baron's right - in
normal driving, this shouldn't be a problem (you shouldn't shift to first while in motion).
As to the problem - if it's 'catching' it will be the 1st-second coupling sleeve catching
on the teeth of the first main gear. This is bad - you'll burr the teeth on the sleeve
or the gear, so don't do it.
If it's just hard to press it's because the baulk ring has to synchronise the speeds of the
gear and the shaft before the sleeve can engage...
Regards,
Saliya
Edited by saliya
my bad so it does have synchros for first. but it doesn't change the fact you shouldn't be downshifting to first. hillclimb is a different story. but i don't think that's what he's talking about.
Learn how to double declutch.
Generally not taught these days but this smooths down shifts remarkably and reduces wear on the gearbox (doesn't hurt on upshifts either ;) )
Being an old bastard and all, I had to learn this when driving trucks without syncros.
and i how might i do this? just clutch, neutral, clutch, gear? if that's the case i don't really get how that helps? not questioning that it does, i just don't get how! i don't understand gearboxes at all. that picture means nothing to me. :)
Hey,
depress clutch -> neutral -> release clutch -> rev match to new gear -> depress clutch -> new gear -> release clutch
The synchro matches the input side of the box (connected to the clutch) with the
output side of the box (connected to the back wheels) for the relevant gear before
the sleeve engages.
While in neutral you rev-match to the RPMs that the new gear will require (clutch must
be out - motor must be connected to gearbox). So you're reducing the work that the
synchro needs to do.
It also means that you need to know what RPMs your intended gear will need at your current road speed.
Regards,
Saliya
Hey,
the sleeve engages.
Regards,
Saliya
And thats so difficult, thats why they invented syncros :)
So really, just dont shift to first on the roll. You really shouldnt need to in a street car on the street. If your driving instructor/dad taught you that, then no offence they are just wrong. If your going that slow you should have to stop.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
