Hi guys,
I have split front s steel dump / front pipe running into my 4" HKS Hi Power Exhaust into a standard catco cat converter.
I can get the CATCO Metal Cat 4" Catalyic Converters at a reduced price from a friend and they claim to flow at 1054 CFM
or I can buy a METALCAT 3.5 Inch Cat Converter and have to run 1/2 inch reducers to make it fit. (they dont make 4")
I think going down in size is stupid and i should go with the catco even if their CFM claims may be a bit overrated.
I need some advice guys.
Thanks
Hi guys,
Thanks
Hey,
I don't know that the claims are overrated; if the cat is the one I'm thinking of the actual area of
flow through the cat material is more like 6". Does it look like this:
You might be able to cut the ends off the metalcat cat to get a true 4" cross-section; I don't know.
Regards,
Saliya
hey mate .. I am not actually sure what a 4" catco metal cat looks like... but i can get them cheaper...
if thats what they look like lol f**k yeah thats huge.
anyone on here use the catco's???
I do. But as said earlier, all of the metal substrate cats are much the same
The size is the diameter of the center section, not the inlet and outlet size, so a 4 inch is 4 inch center section, it could still have 2.5 inlets. they are available in a variety of inlet sizes and centre diameters when not flanged. Bolt on ones are usually 3 inch in/out to suit the stock flanges.
4inch in/out metal cat with 5inch body
also if you got the 3.5 i cant see it making any restriction as you said your runing a split dump/front.. so you've obviously got a largish low mount.. 3inch flows plenty unless your making more than 450-500hp at the treads.. i cant see the smaller one being any restriction
Edited by rb26s13
what sort of cat is that? looks the part!
If i get a 4inch in / outlet cat converter I wont need to take it to a muffler shop to have it fitted because I wont need to mess around with inlet / out sizes, just gaskets and maniseal!!!
Plus a 4 inch in / outlet cat is bloody huge..
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
