  • Replies 86
Ferah, your award was a shoe in!
Not one other group really made an effort, you guys did and good on ya.
Salon stands are not the easiest of things to oraganise... thank god im not doing one this year.
yes i must admitt it wasnt easy but we had such a good weekend! >_<
I think maybe other clubs get more into the whole 'theme' thing when its semi finals....i dunno, maybe at the end of the year more clubs will do a proper setup
yes i must admitt it wasnt easy but we had such a good weekend! :(
Its never easy. There is always about 15 things that go wrong. >_<
But the weekend is a good one if your into it :sorcerer:
Ye, semi's seems to attract more of it as its a much larger show aswell.
I don't know if you're being serious... but no. It's a Garret GT42 comp, with 1.06 rear I think..
I dropped the car off there with him on Friday. Its a T88
EDIT: I'll assume we aren't talking about the same Benny here. I am talking about Benny Kashima from Hi Torque with his 180sx, the pink pussy, not Ben from RPM
Edited by [WLDCRD]
yeah thats flywheel power, it should probably make around 150rwkw stock
so its not too bad but probably something is up, best to check it out
an r33 makes around 140rwkw stock or 187kw at the flywheel
Neos made 206 at fly stock didnt they... Ferahs pulled 132.9.
U should put ur dyno print out up ferah... People will be able to help u out.
ferahs reading is at the rear wheels
dynos give power output at the rear wheels
marketing or car "factory" figures are all flywheel figures
so 206kw at the flywheel is about 150rwkw maybe 160rwkw
It sounded like i meant at the fly. My bad.
Yes i think hers is a little low... auto little less power but catback little more power. I think u will be satisfied when u take it on tuesday ferah! It will go well.
The dyno at autosalon was suss
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
